Mon Mar 07, 2011 | Post #1 | Nikita
Join date: Jan 2011 | Post subject: Entrance door direction for south facing home.
Hello snehal,
As I know about vastu and search I found that this is ok. As per Vastu recommend South facing homes can hold a door in southeast or in south.
Tue Mar 08, 2011 | Post #2 | sabina vanjani
South of South-East or the direction between SE and South is okay fr an entry door. If you have a balcony in the North, NE or East you should keep the same light and open.
Thanks | |
Sun Mar 13, 2011 | Post #3 | Dinesh Manaktala
Well Snehal,
If a plot or flat is facing towards South then its door must be in Eastern part of the wall. There's no harm in this. But if u put the question here that means u are having some problem and u think it would be because of vastu. U cannot change this because of financial problem means U definitely have some problems with finance.
But as well as i think its not because ur door is in S/E. South is called the corner of wealth. I think there must be some water source in this direction. Water in South East is harmful for the finance of the family. If it is so, better if u clear that source from there and till its not possible, place a red bulb of low power in that side and connect this with inverter so that it would be enlightened for all the times. Or keep a candle there somewhere in the corner and light it up for at least 45 mins on daily bases.
It wont completely remove the ill effects but will definitely decrease them and u'll feel the result withing 27 days.
Best of luck.
Dinesh Manaktala,Architectural and Interior Designer and Vastu Consultant, Interiology, Saharanpur | |
Wed Mar 16, 2011 | Post #4 | yogita
Join date: Mar 2011 | Post subject: bedroom in the norht east direction
hello ,
my master bedroom is in north east direction and i don't know since the time we have started leaving in this house my nature has changed from charm to very aggressive, same is the case with my husband. secondly the room is very hot. can you suggest the changes which will help me. | |
Thu Mar 17, 2011 | Post #5 | Nikita
Join date: Jan 2011 | Post subject: Master Bedroom Direction.
Hello Yogita, North east area should have a children room and the master bedroom should be in southwest area of the house. If you can, then please try to change the position of your master bedroom in south west.
Tue Mar 22, 2011 | Post #6 | fakruddin
Join date: Mar 2011 | Post subject: HOW TO CREATE A POSITIVE ENVIRONMENT IN YOUR HOM...
I am staying in a single room with family. East facing. South road. South side Big gate covering whole south side. Small gate at South east. stairs at north-west and under that bathroom. beside to that single room. South side is open for parking. We bring water from out side. we bring water other side of the south road towards south-west direction. We fill the drum which is placed beside to our main door. Full of problems and debts. Can u advice. | |
Vastu Shastra-Construction Questions (39) | |
