Home -> Forums -> Construction -> Start Construction -> TORSION REINFORCEMENT
Thu Apr 14, 2016Total posts : 3
Topic: TORSION REINFORCEMENT
I KNOW TORSION REINFOCEMENT IS PROVIED AT CORNER OF A BIG ROOM BUT I DONT KNOW THE POSITION OF THAT REINFORCEMENT IN BEAM? SO EXPLAIN THE POSITION OF TORSION REINFORCEMENT IN SLAB BARS? IT IS FIXED AT MIDDLE OF BEAM OR AT UPPER END OR LOWER END?
IF IT IS POSIBLE TO GIVE A FIGURE OR PHOTOS.....SO PLEASE GIVE THAT.
Thu Apr 14, 2016Post  #1
Dear Mada
         In my view the torsion steel is at L/4 or L/5. It is better if you have proper structural design form civil engineer of your drawing.
Fri Apr 15, 2016Post  #2
THANKS SIR, I KNOW THAT TORSION STEEL IS AT L/4 OR L/5,BUT I DONT KNOW WHERE TORSION BARS ARE FIXED IN BEAM AND HOW?
Fri Apr 15, 2016Post  #3
Dear Mada
       The torsion bars are fixed on the both ends at top of simply supported beam. In case continuous beam these bars are placed at the end and on the middle supports at top of beam.
1180
1512
1261
1406
2382
2575
Specification of ‘Plastering’
6477
1716
Reinforcement details for ductility
Last answer on 7/22/2013 7:31:49 PM. by Rudra Nevatia. Forum started by shivakumar
1195
How do Engineers calculate the Reinforcement needed for house. Is it possible to
Last answer on 9/25/2018 11:57:50 PM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
1152
Does Indian Standards for construction specify the structure reinforcement requi
Last answer on 7/4/2020 2:00:43 AM. Forum started by Vineeth V
2244
1838
3318
2826
1791
Last answer on 4/13/2016 1:01:09 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1514
1850
SLAB LOADING
Last answer on 12/24/2015 4:05:10 AM. by JAI PRAKASH. Forum started by ANISH
1746
beam rod details
Last answer on 7/27/2016 1:14:29 PM. by S L Gupta (Civil Engg). Forum started by brigith jose dopson
1710
2480
3305
3318
4449
4020
2246
2724
4233
5204
2394
2319
2023
2463
2141
3214
2073
12540
2187
2029
2748
