Home -> Forums -> Construction -> Start Construction -> Teak wood purchasing
Tue Dec 01, 2015Total posts : 2
yogeswaran
yogeswaran
Topic: Teak wood purchasing
hi,
  I'm constructing a house and would like to purchase teak wood for doors/windows. can you guide me how to select a good timber
TIA,
Yogeswaran
Wed Dec 02, 2015Post  #1
Select any known shop. only a big timber house can give you original teak.
Wed Dec 02, 2015Post  #2
     See the link below for timber purchsasing
http://www.gharexpert.com/articles/Raw-Material-1590/Purchasing-Guidelines-Timber_0.aspx
1741
11392
WHAT IS TH PRICE OF TEAK WOOD IN BANGALORE
Last answer on 12/28/2011 10:07:52 PM. by S L Gupta (Civil Engg). Forum started by ramesh s
1477
I would like to know about what are difference and durability with cost about Ru
Last answer on 3/6/2017 4:18:34 PM. by Sree. Forum started by Sree
2017
62
doubts regarding the purchase of wood....
Last answer on 3/14/2011 11:03:12 PM. by Dinesh Manaktala. Forum started by sangeetha
3459
17434
i want idea about main door which is teak wood but simple design to make modern
Last answer on 8/15/2013 7:15:40 PM. by GUNA. Forum started by ashok
2576
JOINERY WORKS
2407
What are various materials used for windows?
Last answer on 5/14/2014 1:56:15 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
1766
What could be the cost of Teak wood main door (4.5'x9'), double unequal shutters
Last answer on 3/5/2016 9:49:38 PM. by JAI PRAKASH. Forum started by Suhas
3729
Door wood and Frame
Last answer on 2/19/2013 11:35:56 AM. by S L Gupta (Civil Engg). Forum started by paresh
10446
2488
Wood quality check
Last answer on 9/1/2015 4:22:59 PM. by JAI PRAKASH. Forum started by Vijay
2064
2296
My husband wants to furnish the doors and windows completely with teak wood..but
Last answer on 8/5/2011 11:12:02 AM. Forum started by sangeetha
1599
I understand TEAK WOOD (BURMESE AND KERALA) are expensive., if I want the next r
Last answer on 1/10/2016 9:01:45 PM. by JAI PRAKASH. Forum started by Vikram
2169
Buying wooden furniture
Last answer on 9/30/2021 12:02:50 AM. by Sunchez721. Forum started by Solomon
3024
What is the checklist for wooden doors?
Last answer on 3/13/2010 8:35:00 PM. by K Anjaneyulu. Forum started by vijaykumar
2705
2442
3265
3278
4424
3970
2187
2695
4205
5159
2370
2288
1991
2441
2110
3190
2041
12508
2157
2005
2721
Teak
Teak wood frame
Buying tips for Brick Blast
Buying
Buying tips for Cement
Tips to remember while purchasing a garden bench.
What are various types of woods used in doors?
Primary and Secondary varieties of wood like Teak wood, Deodar, Shisham.....................
Wood
Wood Roof Shingles
Hard
