Home -> Forums -> Construction -> Basement -> Termite treatment chemicals to be mixed in concrete mixture
Wed Jun 27, 2012Total posts : 2
George Kattapuram
George Kattapuram
Topic: Termite treatment chemicals to be mixed in concrete mixture
Dear All,
I would like to know if it is allowed to mix anti termite chemials to cement concrete that will be used on the basement levels.
It has been suggested per people that to avoid termites, treat the ground bfore placeing concrete below the footings, and in addition mix the chemical into the cement concrete.
I want to know if this is advisable and correct, as the chemical may interfere with the concrete setting, and strength. ?, and what is the correct method of anti termite treatment.
best regards,
 George
Wed Jun 27, 2012Post  #1
Dear Georage
Treat the soil with antitermite chemical at foundation level, in foundation and under floors before laying floor and all the wood work will be given anti termite chemical coat before fixing it. It is no worth while to mix in concrete. There are many articles about termite treatment at website gharexpert.com in safety section of construction. Link given below for ready reference.
http://www.gharexpert.com/articles/Termite-Control-2000/Termite-Control_0.aspx
Thu Nov 08, 2012Post  #2
junkie9411
junkie9411
Termites treatment chemicals is good methods for termite treatment, you should use it
2675
Termite Treatment
Last answer on 9/25/2020 2:58:44 AM. by S L Gupta (Civil Engg). Forum started by Hidayath
1767
1460
2499
Protect your Home from Bugs
Last answer on 12/29/2010 2:52:39 PM. by Nikita. Forum started by trimbak
2873
Types of Cement
4736
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by Girish
3770
concrete mix design software
3278
3591
Per Sq:ft rate for flooring
2319
Water proofing method
1869
Roof Painting
1686
2829
2237
2468
Readymix Concrete Mixture
Last answer on 8/17/2012 12:01:44 PM. by jmahajan. Forum started by Navneet Shahrawat
2898
Terrace water proofing
3205
Concrete Mixture
2132
For termite control
Last answer on 7/14/2018 9:59:57 AM. by kmiller1987. Forum started by ARVIND GOYAL
9061
makan map
2774
17223
1993
2157
design of column
2283
2253
Underground water tank
2658
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2798
1970
ffff
1872
4212
Selection of cement ..
3465
2016
Regarding construction
3155
Basement Water proffing
2015
Acid staining
Termite Treatment for windows- Precautions and tips to remember
Termites are major wood destroying insects. We must take every precaution while doing any construction. Here are few t..
What are anti-termite chemicals? How to control them?
For Termite Control in existing as well as new buildings, soil treatment with chemical is essential in order to protec..
Concrete Mix Ratio
Termite
Termite Control
Have you protected your home from termites? Termites destroy household articles and create unhygienic conditions for i..
Ready
Ready Mix Concrete
Termite Control
Damp
Damp Proofing
Termite
Termite Damage Signs and repairing tips
Termite damage is a worst dream for any house owner. Termites eat wood and this affect almost every wooden product lik..
What precautions do we take in order to make the windows termite free?
The presence sign of termites is through tale tubes. Termites travel in these tubes and are supposed to eat away wood ..
CONCRETE
