Home -> Forums -> Construction -> Tile Flooring -> Terrace water proofing
Tue Sep 16, 2014Total posts : 3
ravi pachipala
ravi pachipala
Topic: Terrace water proofing
hello : need expert advise. I am going for tiles on terrace. I have been advised the below steps for water proofing the terrace on terrace.
1. Apply 2 coats of fosroc brush bond on terrace slab.
2. Add water proofing chemical in the concrete mix of tiles laying.
Can some one advise me the detailed steps of water proofing while going for tiles laying on terrace.
regards,
Ravi
Tue Sep 16, 2014Post  #1
Use 1 or 2 coat of Dr. Fixit with cement then apply charcoal on it before sand and tiles.
Wed Sep 17, 2014Post  #2
Dear Ravi
           For terrace water proofing
Clean the roof and do 2 coats of bitumen,
lay polythene sheet on hot bitumen
lay 1'' thick mud plaster and than lay dry earth for giving the proper slope do drain  water.
Lay brick tiles with mud and than grout the surface with cement mortar 1;3.
Mon Jul 13, 2020Post  #3
In the realization of waterproofing systems for balconies or terraces it’s important the ability to know how to evaluate and consequently choose the waterproofing system best suited to the existing situation regardless of whether it’s a new construction or the adjustment of a pre-existing situation; it’s therefore necessary realize it to perfection, paying particular attention to all types of details and to the accurate treatment of them, which in most cases represent the critical points from which water leaks occur causing the subsequent problems.
In order to waterproof a balcony or a terrace, first of all it’s necessary to evaluate the existing conditions of the area to be treated because, depending on the state of conservation of the balcony or terrace on which you want to intervene, there are different solutions and different steps to follow, more or less invasive to restore or to do a new waterproofing system.
The first thing to evaluate is the state of the existing flooring, that is the visible layer, which is also the easiest to investigate regarding its state of conservation. This evaluation can be carried out, for example, by checking if the volumes of the joints are consistent or missing, because in most cases it’s from the joints that the water starts to infiltrate and therefore the waterproofing effect of the finish is missing.
Consequently, the water will begin to deteriorate the whole pack, with serious damage to the elements. In parallel, it’s possible to check the status of the elements of the flooring, in fact, even if these are for outdoor and therefore waterproofing, any cracks or breakages of the same provide access to water creating infiltration points.
Tile Flooring-Construction Questions (38)
2768
2303
2233
1800
2236
3163
APP membrane
2341
lift pit water proofing
3828
ROOF WATER PROOFING / TANKING
roofing on open terrace
1844
3968
water proofing of water tank
2340
Waterproofing leaks from terrace
Last answer on 5/15/2015 11:08:13 AM. by prit123. Forum started by island
10048
3076
Water Harvesting System
1755
1958
2400
946
Sir, I have constructed 12000 lit concrete sump. Plastering done with cement,san
Last answer on 7/3/2020 9:23:58 PM. Forum started by sunder
2319
Water proofing method
3010
Flooring in Car Porch
Last answer on 5/31/2021 3:06:20 AM. by Keira Nail. Forum started by P. Panchal
3517
What is the specification for vertified tiles?
Last answer on 12/31/2020 1:19:32 AM. Forum started by Kamal Jindal
2691
Brick tile flooring
Last answer on 7/13/2020 12:31:14 AM. by leelindsey. Forum started by Vinay
2612
ceramic tle
Last answer on 7/13/2020 12:22:37 AM. by leelindsey. Forum started by sabakhan
3056
Last answer on 7/12/2020 10:44:29 PM. by Girish. Forum started by joseph
2715
Balcony flooring
Last answer on 7/11/2020 8:10:08 PM. by S L Gupta (Civil Engg). Forum started by sdk
2350
Need Suggestion
2291
2621
Tiles
Last answer on 7/11/2020 8:08:42 PM. by freekundli. Forum started by Ahmed
2486
Vest tiles
Last answer on 7/11/2020 8:07:00 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
1670
1493
I need to know more about this tile n price and dealer near by my place
Last answer on 3/5/2016 10:24:39 PM. by JAI PRAKASH. Forum started by Rakesh
1489
white bathroom tiles for terrace flooring
Last answer on 10/17/2015 9:47:25 AM. by JAI PRAKASH. Forum started by preeti
1578
How to Apply Tile flooring in a room
Last answer on 3/24/2014 2:15:29 AM. Forum started by Purvi Panchal
3623
Vitrified Flooring FloorBase on RCC Slabs
Last answer on 5/20/2013 4:10:45 PM. by S L Gupta (Civil Engg). Forum started by Rajesh
down POP designs
2633
tiles
2318
Floor Tile Area difference
Last answer on 7/19/2012 6:28:30 PM. by Ramesh. Forum started by Ramesh
2731
terrace floor tile
Last answer on 9/14/2011 2:03:17 PM. by S L Gupta (Civil Engg). Forum started by nitin dahisaria
Roof Garden
Damp
Damp Proofing
Protect
Preventive
Fire
Basement Design Ideas
Guideline for laying DPC
Earthquake
