Home -> Forums -> Construction -> Start Construction -> Terrace water proofing
Mon Aug 29, 2016Total posts : 3
Er.S.K.Jain
Er.S.K.Jain
Topic: Terrace water proofing
The building construct before three years. And no any terracing work done at the time of construction.
At present water log on terrace, and seepage start from roof.
Roof is R.C.C. on frame structure building. Terrace area is more than 4000 sft.
I like to know the details for best way of terracing and water proofing with per sft cost in UP.
Mon Aug 29, 2016Post  #1
Dear Jain
         You have a good knowledge about engineering.
In my opinion,
Clean and dry the roof surface than apply hot bitumen @ 1.65 kg per square meter than lay polythene sheet on bitumen surface while some what hot.
Lay 1'' thick mud faska that mud with tura.
After this lay good earth accordingly to maintain proper slope rammed and lay brick tiles with mud. After that grout the surface with cement coarse sand mortar 1;3.
If needed do 1;2 flush cement pointing and cure it at least for 7 days.
Mon Aug 29, 2016Post  #2
Er.S.K.Jain
Er.S.K.Jain
Post subject: Continue to Sri S L Gupta
Dear Sir Sri S L Gupta,
In present time many engineers suggest for polymer coating/ fiber net and different chemicals like Dr Fixit and other.
Also what about brick bat coba treatment.
it is very confusing what is better traditional as you suggest or by chemicals followed by brick coba or only brick coba.
Please answer your guideline opinion in detail.
Thanks for your knowledgeable answer.
Tue Aug 30, 2016Post  #3
      Actually I have practical knowledge about tile terracing for long time in the field but have bookish knowledge only about the other treatment.
2766
2894
2232
1799
2236
3163
APP membrane
2338
lift pit water proofing
3828
ROOF WATER PROOFING / TANKING
roofing on open terrace
1844
3965
water proofing of water tank
2339
Waterproofing leaks from terrace
Last answer on 5/15/2015 11:08:13 AM. by prit123. Forum started by island
10046
3076
Water Harvesting System
1754
1958
2399
944
Sir, I have constructed 12000 lit concrete sump. Plastering done with cement,san
Last answer on 7/3/2020 9:23:58 PM. Forum started by sunder
2319
Water proofing method
3295
3309
4002
2133
2058
Roof Garden
Damp
Damp Proofing
Protect
Preventive
Fire
Basement Design Ideas
Guideline for laying DPC
Earthquake
