Home -> Forums -> Construction -> Finishing -> Thermal Insulation of Home
Mon Mar 29, 2010Total posts : 8
akkulshrestha
akkulshrestha
Topic: Thermal Insulation of Home
very usefull.please intimate the BHUKAMPRODHI design of a house
The comment above talks about the article   "Thermal Insulation of Home"
Tue Mar 30, 2010Post  #1
Post subject: Reply-Thermal Insulation
Resp. Kulshrestha,
Please read the article on  link given below for information on BHUKAMPRODHI (earthquake resistant) design of house:
1. http://www.gharexpert.com/articles/Earthquake-1461/Make-your-home-earthquake-proof_0.aspx
2. http://www.gharexpert.com/articles/Earthquake-725/Which-recommended-factors-safety-building-in-earthquake-prone-areas--0.aspx
3. http://www.gharexpert.com/articles/Earthquake-723/Which-type-building-materials-construction_0.aspx
S.L.gupta
Fri Jul 30, 2010Post  #2
mukeshsamania
mukeshsamania
Post subject: Thermal Insulation of Home
Will you please tell me about detail drawings. staircase, swimming pool, water tank
Thu Jan 20, 2011Post  #3
shaik
shaik
hello, can u please give me an idea to built a livingroom and bedroom with attach bathroom in 27*27fts
Mon Jun 13, 2011Post  #4
sanjay
sanjay
I am planning to install a home theatre system in my house in a room dedicated for this. I would like to receive some advice on room acoustics on walls, lighting ideas. Also i would like to know any of the person/ company in navi mumbai who can help fit and tune the system and who has contacts with associated functions like carpentry, LED lighting persons, a/c installation, plaster of paris on one wall for projection screen, etc. Any suggestions welcome and appreciated very much in advance with thanks.
Wed Mar 27, 2013Post  #5
pkpatnaik
pkpatnaik
what should be construction cost upto plinth level,my contractor rate is rs1250per sqft for three storied building,my plinth area is1250sqft each floor, pl reply.
Mon Aug 04, 2014Post  #6
S.K.LAHIRI
S.K.LAHIRI
Can any one suggest whether EXTRUDED (not EXPANDED, which in layman's term is thermocole etc)POLYSTYRENE sheet for roof thermal insulation is available at India. This system is normally used with geo-textile sheet and fixed as stand-alone. If available - what is the cost and who are the supplier?
Tue Feb 10, 2015Post  #7
SK Mittal
SK Mittal
I wish to provide heat insulating material like thermocole over which brick bat coba is to be done for waterproofing. Can someone suggest the sequence of layers to be done.
Mon Oct 19, 2015Post  #8
abhijeet pawar
abhijeet pawar
Hi, We stay in Mumbai. Currently the weather here is very hot and top it up..we stay on the top floor. Which get heated up quickly and room stay heated most of the time..Even A/c doesn't prove helpful sometimes. We are thinking of insulating the room and also do some structural change. We stay in a 1RK flat which comes arround 300 sq/ft area. However, the kitchen is quite spacious. Therefore, thinking of converting it to a bedroom and the bathroom to compact kitchen and the divide the toilet into a mini bathroom and toilet..There is a sufficient space to do it. We are also close to highway, therefore, it very dusty as well. Also would like to know how can we make the house more dust free. Kindly let a quote for the same.
Finishing-Construction Questions (36)
INSULATIONS
Last answer on 11/16/2009 6:59:34 PM. by Girish. Forum started by Girish
1548
Insulating roof using used cement bags
Last answer on 3/26/2015 1:35:41 AM. by JAI PRAKASH. Forum started by Arvind Bhaskar
2703
home security systems
Last answer on 7/3/2020 10:55:36 PM. by S L Gupta (Civil Engg). Forum started by farrukh tahir
1810
2829
1678
Concrete Roof Insulation
Last answer on 6/25/2016 11:19:30 AM. by S L Gupta (Civil Engg). Forum started by Omar Chaudhry
2138
Roof insulation
Last answer on 9/20/2014 12:13:54 PM. by S L Gupta (Civil Engg). Forum started by sb
2047
Insulation and energy efficient houses
Last answer on 9/28/2011 5:25:10 AM. by Mohammad Baqar. Forum started by Mohammad Baqar
3895
Construction software
Last answer on 1/2/2021 5:22:24 AM. by DK. Forum started by tvammu
2734
A Curtain Raiser
Last answer on 7/3/2010 2:58:58 PM. by ashok. Forum started by preetigupta
2971
duration of constucting home
2310
New Pergolas Design For Your Home
Last answer on 5/28/2015 10:09:11 AM. by berashton. Forum started by berashton
2001
1820
sir my plote sige 24*47 i want make a home please sages me how to make wastu hom
Last answer on 8/16/2015 9:44:14 PM. by JAI PRAKASH. Forum started by nirmal soni
1569
2163
Last answer on 7/4/2020 2:33:32 AM. by S L Gupta (Civil Engg). Forum started by Monish Salhotra
1301
Can I have vastu suggestions for my home?
Last answer on 5/3/2018 11:01:36 AM. by deep. Forum started by deep
1400
1620
2018
Last answer on 2/2/2022 11:26:31 PM. Forum started by manjunath
2591
Elevations Required
Last answer on 2/2/2022 10:53:23 PM. Forum started by gangula
3202
Cracks on the walls
Last answer on 1/14/2022 10:40:04 AM. by S L Gupta (Civil Engg). Forum started by devjani roy kashyap
2897
Wall painting
2083
CEMENT PANI - Plaster Works
1951
Triangle House roof
Last answer on 1/14/2022 4:58:49 AM. by S L Gupta (Civil Engg). Forum started by tayyab
3870
Last answer on 1/14/2022 4:09:54 AM. by S L Gupta (Civil Engg). Forum started by Sameer
2332
tiles or marble
Last answer on 12/4/2021 5:12:27 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3536
stone wall cladding
1515
help
1542
POP OR GYPSUM
10933
Lappam vs Wall Putty
1932
Last answer on 3/5/2016 9:18:00 PM. by JAI PRAKASH. Forum started by raj
1834
1961
1880
Final Handover
Last answer on 5/14/2014 2:15:33 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
2117
Thermal
No one likes to work in an uncomfortable environment where the temperature is either too hot or too cold. It is import..
A
Results of 'Design A Dream Home' Competition
The results are following.
Home Interior Decoration Ideas
Not all home decorating ideas require a heavy investment of time and money. If you're looking for a few affor
Protect
Protect your Home from Bugs
Protect
