Home -> Forums -> Construction -> Bricks -> Thickness of internal partition wall
Fri Sep 09, 2016Total posts : 2
Sanzana Hosen
Sanzana Hosen
Topic: Thickness of internal partition wall
Is it possible to provide 3" thick brick partition wall as internal walls? Will there be any problem in installing electrical and sanitary ducts? Also I want to know upto what height a 3-in brick partition wall can be used without any problem to limiting slenderness ratio.
Fri Sep 09, 2016Post  #1
bhuvaneshwaran bn
bhuvaneshwaran bn
Post subject: Depends on the Material u use Its Partition wall.
Brick Wall Minimum of 5 Inch  Thick (After plastering) - This is ruled Out.
1st Option -Wooden Partition is ur Next possibilty. electrical wiring is taken care.
2nd Option-Aerocon Brick which u wil get around 3.5inch - 4inch finish.
Note:- The Above are my suggestions.Anybody can come with different idea will help Me and Others.
Wed Jun 19, 2019Post  #2
          Thanks for visiting the site.
Delete
Living room-Interior Questions (38)
3379
Last answer on 8/1/2010 11:25:10 AM. by ravi. Forum started by amy_bsnl
1697
wat do u think if u are a student of interior designing ( about ur field)?
Last answer on 5/17/2019 12:43:51 AM. by S L Gupta (Civil Engg). Forum started by swati
829
the best materia for hom construction
Last answer on 12/24/2015 4:23:31 AM. by JAI PRAKASH. Forum started by maris.builds.house
1078
Suggest a plan for 45X45 plot.
Last answer on 5/27/2015 10:11:10 AM. by seema tyagi. Forum started by Murali
813
Is Basement allowed in 60*40 site
Last answer on 4/2/2016 11:40:07 AM. by S L Gupta (Civil Engg). Forum started by Surya
4058
Last answer on 4/3/2013 4:12:03 PM. by S L Gupta (Civil Engg). Forum started by mayank
990
Can we have an open space in between kitchen and bedroom and also two toilets i
Last answer on 1/16/2015 1:32:01 AM. by JAI PRAKASH. Forum started by Gayatri Aanand
1015
want to put bath space seperators to seperate the shower space whuch is 4.5 by 3
Last answer on 9/12/2011 10:13:27 AM. Forum started by NAGIR REDDY
647
Last answer on 12/26/2016 1:20:47 PM. by S L Gupta (Civil Engg). Forum started by vinu
987
Dear compatriots!Do you use glass mosaic tiles to enhance your housing experienc
Last answer on 5/5/2015 12:25:53 PM. by S L Gupta (Civil Engg). Forum started by Keshav
2660
CONSTRUCTION OF A DUPLEX
Last answer on 3/2/2011 10:17:01 AM. by Mohini Sharma. Forum started by Phani Vardhan
954
Dear Sir iam sr.civil engineer with adequate experience.so please tell me the pr
Last answer on 7/31/2014 10:26:07 AM. Forum started by SANJAY DUSANE
1647
Add aesthetic touch to your home with Asian home décor
Last answer on 12/5/2014 11:43:46 AM. by seema tyagi. Forum started by Matthew Davis
944
Please give me commercial bulding plan 35feet front* 160feet deep space
Last answer on 7/8/2014 11:47:55 AM. by seema tyagi. Forum started by Asif Inamdar
1437
Last answer on 9/23/2012 3:04:33 PM. Forum started by rizwan
1522
home security systems
Last answer on 5/1/2011 12:50:23 PM. by Rohan Jacob. Forum started by farrukh tahir
1440
Last answer on 8/6/2011 2:32:51 PM. by sabina vanjani. Forum started by nita
2375
space saving ideas for kids bedroom
Last answer on 2/5/2012 1:00:46 PM. Forum started by mandep
2038
Last answer on 5/2/2012 6:03:27 PM. by soujanya981. Forum started by sajid
2097
Last answer on 2/22/2019 2:14:58 AM. by S L Gupta (Civil Engg). Forum started by silochonie
435
yes I would like to, bcos base on what z going on in the country. I won't mind i
Last answer on 5/23/2017 10:29:23 AM. Forum started by adebayo segun samuel
722
KINDLY SEND 24* 45 CORNER HOUSE FRONT AND CORNER ELEVATION 3 STORIES
Last answer on 2/7/2017 12:59:59 PM. by S L Gupta (Civil Engg). Forum started by balwinder singh
530
Hide TV cables in Wall
Last answer on 2/1/2017 12:45:23 PM. by S L Gupta (Civil Engg). Forum started by yasothabalanr
789
My plot size 20sqft × 20sqft West facing i request to plan 1hall 1kichan (1rk)
Last answer on 1/18/2017 2:11:15 PM. by S L Gupta (Civil Engg). Forum started by Ganesh nale
705
nterior Decoration
Last answer on 9/9/2016 11:32:02 PM. by bhuvaneshwaran bn. Forum started by Satvinder kaur
1841
Tips For Small Space Living
Last answer on 6/15/2016 10:55:13 AM. by amrath. Forum started by nana
2567
11 ft wardrobes till ceiling ?
Last answer on 6/6/2016 1:31:07 PM. by S L Gupta (Civil Engg). Forum started by sushantsah
809
Can we create Concrete Floating Shelves
Last answer on 5/3/2016 12:36:31 AM. by JAI PRAKASH. Forum started by ravi
821
Show case design for Hall/Living Room
Last answer on 4/25/2016 11:59:55 AM. by S L Gupta (Civil Engg). Forum started by Pavan1057
904
TV WALL OR UNIT DESIGN
Last answer on 12/12/2015 6:43:50 PM. by JAI PRAKASH. Forum started by SACHIN
FRONT ELEVATION DESIGN FOR G+4 BUILDING
Last answer on 10/5/2015 9:24:51 PM. Forum started by kkr
1006
Last answer on 7/16/2015 10:45:58 PM. by JAI PRAKASH. Forum started by nataraj
946
Muje apne ghar elevatin benwana he plz hellp my
Last answer on 6/16/2015 12:04:12 PM. by seema tyagi. Forum started by dev singh
1777
Last answer on 6/16/2015 4:09:54 AM. by JAI PRAKASH. Forum started by Koteeswari
3906
I want design for glass partition between Drawing room and lobby.Dimensions are
Last answer on 5/12/2015 2:43:34 AM. by JAI PRAKASH. Forum started by ravneet sidhu
976
pls sen colour code
Last answer on 2/4/2015 11:38:16 AM. by S L Gupta (Civil Engg). Forum started by santosh
2337
Last answer on 12/10/2014 10:12:46 PM. by JAI PRAKASH. Forum started by Vishnukant Phafat
1570
need interior designer..
Last answer on 10/14/2014 11:40:19 AM. by amrath. Forum started by sunny
2361
estimation
8322
7257
3273
2124
Wall Thickness
1525
4128
2212
2585
what is the wall thickness for a 9000 sqft building
Last answer on 4/3/2021 12:46:58 AM. by S L Gupta (Civil Engg). Forum started by shankar
2862
4939
3287
i want living room partition idea's my room size is 10.5 x 24.7
Last answer on 8/4/2010 10:11:07 PM. by sunilrathi86. Forum started by varu
2459
Requirement of wall wall thickness
Last answer on 6/18/2013 8:01:29 PM. by pendli. Forum started by pendli
3421
Cost of Brick Work
Last answer on 6/4/2014 3:43:02 PM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
1287
I want to build bedroom loft of 2 feet extend from wall. The side walls are 11'
Last answer on 7/4/2020 4:18:19 AM. by Surinder Singh. Forum started by Surinder Singh
3228
I want to paint my house plz suggest the colour for internal rooms & external
Last answer on 2/15/2012 10:39:54 PM. by skycrane. Forum started by vago suzare
2548
3935
load bearing walls
Last answer on 12/7/2020 12:04:44 AM. by mohan. Forum started by mohan
2815
doors on 4.5"partition walls
Last answer on 5/17/2010 7:19:02 PM. by Ramkumar G Krish. Forum started by mohan
7513
Brick Advice Urgent
2879
Bricks
2793
brick calculation
2565
Cost of Brickwork
4894
2821
2350
3172
bricks
5658
5135
Use of Solid Concrete Bricks
1624
1341
1845
1479
1797
2966
fly ash bricks
2230
1723
Glass
Glass Partitions
Do you want natural light in your room or your house is small or you have an open floor plan. You may use glass room d..
Canvas
Canvas Wall Art
Wall
Wall Decor
