Home -> Forums -> Interior -> Bedroom Flooring -> Three Methods Of Wood Floor Maintenance
Tue Aug 09, 2016Total posts : 1
happywork
happywork
Topic: Three Methods Of Wood Floor Maintenance
Proper use and maintenance is the key to extend the life of the wood floor, floor maintenance is also a method, only familiar with its properties in order to better maintenance. Wood flooring in use should pay attention to three aspects.
1. First, we want to keep indoor humidity
Although dried wood processing, reducing the size of the changes, but because wood is a natural material, so the wood will dry humidity with climate change and some deformation; in the northern region, especially if the dry season is open encounter Heating consumers can adjust the humidity by different methods, such as using a humidifier or put a basin of water in the heating and the like; the south to the rainy season, consumers should be more windows open for ventilation, maintain indoor dry; at the same time, the use of wooden floors indoors should be avoid contact with large amounts of water, if water spilled on the floor should be wiped clean.
2. Secondly, to avoid damaging the floor surface
Wood floor finish, should avoid collision with hard objects, sharp scratches, metal friction and so on. Prevent dust, sand and other objects into the room, which can place a doormat at the door, but must be kept clean insole. Do not scratch wood surfaces or wear shoes with metal nail nails sharp objects into the room. You can use some furniture fiber fabric foot wrap, both to make it easier to move furniture, you can also make furniture does not damage the floor.
3. Finally, it should properly clean the floor
In everyday use, keep the floor clean wood floors, cleaning, use a clean broom sweep, and then wring the mop, you can usually use a soft damp cloth graze the floor, of course, be treated like a carpet that was removed with a vacuum cleaner dust on the floor.
Depending on the situation, you can wax once every few years to keep the film surface smooth and clean. If conditions permit, 2-3 months to play a floor wax wood floor surface, so that maintenance better.
the article come from : [url=http://outdoorfloorsupplier.com/]Cheap Outdoor Floor Supplier [/url]
maybe you also like :
[url=http://wpcdecksupplier.com/wpc/10964.html]timber tongue and groove cedar boards[/url]
[url=http://wpcdecksupplier.com/wpc/10965.html]best composite non slip stairs deck[/url]
[url=http://wpcdecksupplier.com/wpc/10966.html]wpc board manufacturers in india[/url]
Wed Aug 10, 2016Post  #1
Dear  Sir
       Thanks.
Bedroom Flooring-Interior Questions (36)
3807
2061
1853
Last answer on 12/24/2015 4:17:23 AM. by JAI PRAKASH. Forum started by paramesh
2517
i have three brothers iam the elder one so which floor i have to take
Last answer on 12/26/2016 1:06:41 PM. by S L Gupta (Civil Engg). Forum started by mrajireddy
3322
Last answer on 12/4/2020 3:40:06 AM. by juhi. Forum started by jeetendar
2328
Last answer on 11/19/2013 1:31:03 PM. by Amit Hasija. Forum started by Toby Tyler
62
doubts regarding the purchase of wood....
Last answer on 3/14/2011 11:03:12 PM. by Dinesh Manaktala. Forum started by sangeetha
2906
I have 50X40 builtup areas with ground floor and want to make 1st floor but not
Last answer on 10/23/2012 11:46:28 AM. by Gunjan Utraja. Forum started by prabha
1191
I have an area of 1944sq feet in this I want graden and three floors house gron
Last answer on 4/23/2018 11:19:21 PM. by S L Gupta (Civil Engg). Forum started by Dilip Teja .G
2024
Industrial Maintenance
Last answer on 5/14/2021 10:32:21 AM. by S L Gupta (Civil Engg). Forum started by MarianneRolfe
1759
1822
Plot size 25*50 please send construction plan for combined family with three cou
Last answer on 5/26/2016 3:34:41 PM. by Beenu Phogat. Forum started by praveen solanki
1397
Options for construction of staircase in east facing two duplex houses where the
Last answer on 9/15/2017 2:56:37 AM. by S L Gupta (Civil Engg). Forum started by Sandeep endla
11990
Last answer on 1/5/2022 9:03:47 PM. by S L Gupta (Civil Engg). Forum started by ajay kalra
48
vaasthu regarding 3 floors.....
Last answer on 3/14/2011 10:54:26 PM. Forum started by sangeetha
1804
Need Advice on Solid Wood Floors
Last answer on 4/30/2014 8:29:12 PM. by Abhishek Garg (Builder & Engineer). Forum started by chintan arora
3002
House Estimation Breakdown
2196
method of road structure, step wise detail caculation of material
Last answer on 3/15/2011 6:14:15 PM. by kanwer sajjad. Forum started by kanwer sajjad
932
any new methods for quick construction ??
Last answer on 7/3/2020 10:05:55 PM. Forum started by PAVAN K
1950
I have a hall which should accommodate both drawing and dining. The room size is
Last answer on 2/7/2022 3:28:29 AM. Forum started by Pallavi
2247
Flooring for house
Last answer on 1/17/2022 11:13:36 AM. by S L Gupta (Civil Engg). Forum started by Archit Jain
2363
Good normal bathtub brand and material...
Last answer on 1/7/2022 2:10:41 AM. by raghuam. Forum started by raghuam
2215
Tiles or Marble for Flooring
2257
Latest trend in wooden flooring
Last answer on 7/4/2020 12:05:48 AM. by paramarsh. Forum started by jaai randive
Best tantrik in india Tantrik Baba ji +919878377317
Last answer on 2/15/2017 1:07:45 PM. Forum started by vvv22
1954
Last answer on 1/7/2017 3:42:26 PM. by Beenu Phogat. Forum started by BALDEV RAJ
1911
flooring
Last answer on 7/28/2016 3:08:23 PM. by Aarav Sharma. Forum started by sumit
1555
1889
Bathroom floor tiles
Last answer on 5/20/2014 8:43:39 PM. by JAI PRAKASH. Forum started by parag
2505
Terazzo flooring
Last answer on 2/9/2013 3:03:01 PM. by Blasio777. Forum started by Blasio777
2056
Bedroom Flooring
Last answer on 1/29/2012 11:18:07 AM. by greatwindowsss. Forum started by Suresh Kumar Regmii
2111
Cheap price floors
Last answer on 12/7/2011 2:40:01 PM. by ravi at Dalmia. Forum started by Huda
1732
Sir, Every things found alright. But we need more details for drawings and mate
Last answer on 11/29/2011 10:42:07 PM. Forum started by Habib
1915
Thanks for your recent feedback.I need some images and design for a kitchen.The
Last answer on 10/7/2011 11:34:29 AM. Forum started by Updesh Singh Bhangoo
1963
It was and its lovely
Last answer on 1/11/2011 7:25:39 PM. Forum started by monze
2857
Reusable flooring options
Last answer on 12/1/2009 12:50:07 PM. by anish. Forum started by Kunal Mehta
Tips for maintaining Flooring
Proper maintenance of flooring is required to retain the beauty of floors and home as well. The flooring preserved nicel
Lawn
Lawn Care Tips
Timely care and proper maintenance are essential to preserve the beauty of lawn. If you want to enjoy prettiness of na..
Cedar Wood
Hard
Wood
Wood Roof Shingles
Maintenance of wooden garden benches.
Wood garden benches are available in a variety of types such as teak, oak, cedar etc. Wood benches provide an artistic
How to Maintain Air Conditioner?
Keeping air conditioner in good state is essential to get comfort from scorching summer. This keeps our body and mind ..
Teak
Teak wood frame
