Home -> Forums -> Construction -> Cracks -> Through hairline cracks above and below electric conduits in roof
Wed Aug 08, 2012Total posts : 1
Amit
Amit
Topic: Through hairline cracks above and below electric conduits in roof
Upper floor of my house was built a year back. Around 3months back i could see hairline cracks on the inner and outer surface of the roof's center (thru crack through which water pass through). Cracks appear to be at the places where electic conduits are laid down and on the both side of the fan box, during rains water drips through these cracks. can you please suggest what is the problem and the remedy.
Sat Aug 11, 2012Post  #1
Amit
Amit
Post subject: cont.
my builder has repaired the cracks with common mortar + waterproofing mixture. and now suggesting to get mosaic terracing to be done to avoid future problems. can you please suggest that such solution will work long time. Also i am very worried about strength of the structure due to these cracks. please help.
Cracks-Construction Questions (30)
2914
Last answer on 1/5/2022 12:27:42 AM. Forum started by Vineet Sethiya
3754
3087
1908
5689
8421
Roof Beam crack
1823
After collecting the electric bil.Then how to keep these electric bills....
Last answer on 2/8/2013 2:28:38 PM. by S L Gupta (Civil Engg). Forum started by Purushotham Reddy
2351
2997
2256
Electrical Conduits
Last answer on 5/20/2014 1:25:16 PM. by ajaywahi. Forum started by ajaywahi
2028
2842
Water seepage from RCC slab
roofing on open terrace
6129
Hair line cracks in the ceiling on new 6 month old house
Last answer on 7/23/2012 3:50:30 PM. by S L Gupta (Civil Engg). Forum started by sanjeev kumar
6881
2275
electric fitting
Last answer on 12/9/2020 5:31:07 AM. by SANJAY DUSANE. Forum started by dspatwal
2722
electrical
Last answer on 7/3/2020 9:50:06 PM. by JAI PRAKASH. Forum started by sunil kumar
1992
cables
Last answer on 7/3/2020 10:07:56 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
3381
Recurring Cracks
4137
5734
1591
How to renovate the broken staircase. please look the attachments.
Last answer on 4/25/2016 1:08:43 PM. by S L Gupta (Civil Engg). Forum started by chitta naik
1525
Cost for Polyurethene Grouting for Leakage from Flat Above
Last answer on 3/28/2015 6:24:30 PM. by JAI PRAKASH. Forum started by Unmesh
6881
2278
2295
cracks in walls
Last answer on 9/4/2013 12:14:18 PM. by S L Gupta (Civil Engg). Forum started by Gagandeep
2058
Cracks in my new house
4035
2648
How To Repair Cracks
Last answer on 5/6/2010 12:31:22 AM. by . Forum started by suni dutt panwar
Electric
Electric Shock Proof Home
Cooper
