Home -> Forums -> Construction -> Raw Material -> Tiles Vs Plaster on outer wall
Mon Apr 14, 2014Total posts : 4
awdhesh
awdhesh
Topic: Tiles Vs Plaster on outer wall
Hi
I want to know what is the difference between using plaster in the outer wall or using tiles. How they get affected by weather ? And what is the cost wise difference.
In Bangalore
Mon Apr 14, 2014Post  #1
Dear Awdhesh
        Any kind of tiles when fixed on the outer wall have more life than plaster work. The weather effect is less on tiles than plaster. The cost of plaster is almost same as the mortar applied for fixing the tiles. Tiles cost is extra as per their type of tiles selection.
Mon Apr 14, 2014Post  #2
awdhesh
awdhesh
Post subject: Tiles Vs Plaster on outer wall
Thank  you Gupta Ji.
If you can answer one more question
What is the percentage of cost of foundation with respect to total cost of construction on a arbitrary
Mon Apr 14, 2014Post  #3
Dear Awdhesh
             The cost of foundation depends upon the design of foundation, where hard soil exist than there is less expenditure on foundation than the soft soil. In general foundation cost is 8 to 12% depends on specification and design.
Mon Apr 14, 2014Post  #4
awdhesh
awdhesh
Thanks a lot Gupta Ji.
9157
1069
building 8" wall onthe slab will effecet the on the outer side
Last answer on 7/4/2020 2:02:31 AM. Forum started by Badhavath Rajeshwar
4626
time for paint and wall putty
2413
COSTING AND STRENGTH OF WALL
2924
2438
Gypsum Plaster Vs S/C Plaster
2350
Need Suggestion
3469
Cost of concrete walls
3530
Is it ok to have,as per vastu, curved outer walls for homes especially if it is
Last answer on 8/31/2011 8:43:43 PM. Forum started by Mathew George
7005
3992
8880
961
SIR,I have made new home and i am staying there for last two months. RCC ground
Last answer on 9/7/2018 1:08:09 AM. by S L Gupta (Civil Engg). Forum started by kajal dutta
3966
water proofing of water tank
27
Rain Seepage from outer wall
Last answer on 4/5/2011 9:16:46 PM. Forum started by Dr Akshay
3475
labour charges rates
2212
Painting interior walls
2776
Is this paint or tiles on wall?
Last answer on 3/30/2011 9:13:41 PM. by Mohini Sharma. Forum started by rupali
2990
details about wall claddings, tiles & all including its rate
Last answer on 10/8/2020 12:45:36 AM. by S L Gupta (Civil Engg). Forum started by laxmi
3075
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11102
2189
2037
Estimate
11122
3072
Steel
3038
use of tmt bar
1642
work turned out by labour
2456
estimate
1762
2991
3605
1943
Cost of Steel construction
1612
2135
READY MIX PLASTER
1864
2223
zero slump concrete
Plastering
Plastering
Tiles
Tiles for Bathroom
Checklist for Cement Plaster
Gypsum
Specification of ‘Plastering’
How to clean plaster ceiling?
