Tue Sep 13, 2016 | Total posts : 3 |
| Topic: Tiles or Granites
Dear Sirs,
I am constructing Ground + One House around 2500 Sq ft...
As per my contractor Agreement we have settled price per sq ft with the consideration of Specification of Vitrified Tiles Rs.50/ Sq ft..
I am pretty ok with Vitrified Tiles as i have seen my friends house in Gurgaon, now the contractor suggest that water in the construction house area is salty one which will erupt the tiles surface soon and tiles would loose the elegant style.. he suggest if we go with Granite with minimum rate of Rs.100/ Sq ft would be better one considering the salty water and does not loose elegant..
Could you anyone clarify, whether the contractor suggestion is correct, I should go with Granite instead of Vitrified Tiles..
Thanks.
Prabhu.M
Tue Sep 13, 2016 | Post #1 | sanjay agarwal
It seems you are talking of Gurgaon. Your contractor has misinformed you as the salt in water has no effect on Vitrified Tiles because in Vitrified Tiles, there is a top protective and decorative layer and the water porosity is very low.
In fact the salty water which you will be used to clean the floor later may corrode the surface of Marble/Granite. Also granite is never recommended for use in residential indoors.
For Vitrified Tiles : For Rooms - Go for PGVT or GVT with Nanotechnology for Sheen. For Parking - Go for Full Body Vitrified Tile For Bathroom - Go for DCT or GVT
You may contact Mr. Rohan Agarwal at 9717157708 and rohan.tech2014@gmail.com for more options and best rates.
Tue Sep 13, 2016 | Post #2 | M Prabhu
Join date: Apr 2015 | Thanks Sir for the prompt reply.. I am reading for my understanding for your suggested tiles models..
I current stay in Gurgaon .... however my house construction at madurai, Tamilnadu...
And I have also some across granite has been used some my known houses at madurai.. not able understand, could you enlighten me why do you suggest granite is never recommended for residential indoors.
Prabhu.M
Wed Sep 14, 2016 | Post #3 | sanjay agarwal
Join date: Apr 2015 | I have provided my contact details.
Granite is a very hard stone with long life and low cost. It doesn't need repolish and'is easy to maintain. It is used in high impact areas such as lobby, staircase , counter top in Kitchen and bathroom. However for Flooring in the House interior (bedroom, D?D room, etc) granite is avoided. Most of the best granites come in dark color.
You can call me for further assistance.
Sanjay | |
Glazed Tiles-Construction Questions (24) | |
Articles that might interest you! | | Uses of Granite in Building Construction In today’s construction industry, Granite is one of the major ingredients. Granite is used in verity of locations and .. | | Granite Countertops A kitchen equipped with granite countertops looks amazing and improves the beauty of kitchen and your home as well. Th.. | | Tile Flooring, designs & installation guidelines One of the fastest growing trends in the flooring, tiles come in a wide variety of styles, patterns and colors. In thi.. | | Tiles for Bathroom Tiles definitely change the overall look of your bathroom. Right selection of tiles is also important in terms of bath.. | | Designing Floors with Ceramic Tiles Flooring whether in drawing room or in living room is basic component and a good design of floor not only looks elegan.. | | Purchasing Guidelines for Marble and Granite Stone Marble stone should be hard, free from any stain i.e. deep cut or mark on the surface. | | Clay Roof Tiles When it comes to tile roofing, clay roof tiles are the most admired roofing material. Appearance and durability of cla.. | | Guideline for Labor for Brick Tile masonry What is brick tile work? What are the guidelines for labor for brickwork in superstructure? Don’t worry about all thes.. | | Guideline for labor for Ceramic or glazed tiles Flooring is important phase of any construction and if you are going for ceramic or glazed tiles flooring you must be .. | | Concrete Roofing- All time material Concrete is an all time material for roofing. Simple flat roofs to sloped roofs, concrete roof tiles offered various s.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
