Tips for Aluminum Paint
Sun Jan 16, 2011Total posts : 1
chitra Tibrewal
chitra Tibrewal
Topic: Tips for Aluminum Paint
Any paint for steel surface?
The comment above talks about the article   "Tips for Aluminum Paint"
Fri Jan 21, 2011Post  #1
Swati Sharma
Swati Sharma
Post subject: Paint for Steel Surface
Hello, Chitra Tibrewal
Oil based paint is used to paint the steel surfaces.
If you want to paint them yourself then try some tips to paint a steel surface:
1.    The first step should be – clean the surface. You can choose brush, spray or roller to paint.
2.    If you want to apply more than one coat then let the each layer will dry before applying the next.
3.    To coat cracks- powder coat is the better option.
4.    Mix the chemicals according to manufacturers instructions.
5.    Also need to wear chemical resistant gloves and face/eye protections also required.
6.    Always paint in dust-free environment.
7.    If possible try to varnish your metal.
i need.s windows aluminium with gllas & fire doors pvc construction in india l
Last answer on 2/24/2022 1:02:52 AM. Forum started by muhammad mansoor
2731
3052
which windows are better for goa wooden or aluminum sliding
Last answer on 5/30/2013 11:04:45 AM. by S L Gupta (Civil Engg). Forum started by oscar
2049
PVC windows
6605
Which chokhat is best wood or iron press or aluminium
Last answer on 8/20/2018 12:28:42 AM. by S L Gupta (Civil Engg). Forum started by Shivam gupta
2967
Tips for Cement Paint
3166
2681
Tips for Dry Distemper Paint
Last answer on 12/8/2009 2:37:57 PM. by Prem Bhatia. Forum started by RIZVI
4703
How can we save money and less wasted through vastu tips at home
Last answer on 7/4/2020 2:01:06 AM. by Deepti. Forum started by shalini kulshreshtha
6197
Vastu and Brahmasthan
10470
Last answer on 11/8/2021 4:04:08 AM. by S L Gupta (Civil Engg). Forum started by kveddy83
2966
Need tips to decorate small(16X7 ft) drawing room
Last answer on 7/17/2020 2:14:48 AM. Forum started by SANJOY DHAR
1916
Tips on Iron chukhat
Last answer on 8/5/2011 12:07:32 PM. by S L Gupta (Civil Engg). Forum started by Reena Sareen
2640
vastu tips to keep the house lady in good health and long life
Last answer on 12/8/2020 10:50:18 PM. by S L Gupta (Civil Engg). Forum started by rajesh singh chandel
3113
please tell me Tulsi plant where site situated in home as vastu tips
Last answer on 12/9/2011 5:33:11 PM. by Amit Hasija. Forum started by Ajay Rana
3962
date of birth 17 july 1968 confirm my vastu tips
Last answer on 11/30/2021 11:37:28 PM. by Johnchen969. Forum started by raghavendra
2558
Kindly tell vastu tips for west facing plot for construction of dental clinic
Last answer on 10/1/2021 5:05:33 AM. by JesseMWoodley. Forum started by Adarsh
2051
vastu tip for west fecing plot
Last answer on 1/22/2022 11:26:02 AM. by S L Gupta (Civil Engg). Forum started by priyanka sinha
1554
Aluminum paint produces fine look, lustrous and superior quality finish on metal and wood. It is tremendously resistant
What affects the life of doors? What can we do to increase the life of the Aluminium doors?
Tips to increase the life of Aluminium doors....
Aluminum
Aluminum Roof
Aluminum
Aluminum door finishes types
There are variety of options for aluminum door finishes available. Let’s get to know the types and recommendation for..
What are the advantages and disadvantages of Aluminium doors?
ADVANTAGES:Strength, stability, weatherproof qualities. DISADVANTAGES: Quick oxidation, easily water stained...
Aluminium
Aluminium doors
Are you looking for a strong door for your home? Aluminum door is right choice for initial security of your room. Thes..
Checklists for Doors and Windows
Doors and windows are costly item in house construction and it provides safety, ventilation and adds the beauty and lo..
