Tips for Dry Distemper Paint
Tue Dec 08, 2009Total posts : 1
RIZVI
RIZVI
Topic: Tips for Dry Distemper Paint
HOW CAN I PAINT (DISTEMPER)ON LIME (CHUNA )WALL. PLS. HELP
The comment above talks about the article   "Tips for Dry Distemper Paint"
Mon Dec 14, 2009Post  #1
Prem Bhatia
Prem Bhatia
Post subject: Application of distemper
If you are painting with dry distemper then dry distemper can be applied after cleaning the lime surface. In case if you want to apply oil bound distemper then rub the surface with sand paper, clean the surface and apply priming coat before applying the oil bound distemper.
Prem
Tips for Oil Bound Distemper
Last answer on 6/15/2010 6:57:04 PM. by bjairaj. Forum started by raja16sep
1721
cement pain for exterior
Last answer on 12/5/2012 3:48:43 PM. by S L Gupta (Civil Engg). Forum started by aammiitt
1832
can I built a small balcony for drying clothes @ N-W (Vayu Moolay)
Last answer on 7/3/2020 10:36:57 PM. by S L Gupta (Civil Engg). Forum started by vijay
664
Can you recommend to me some of the best moisturizers that actually helped your
Last answer on 10/27/2021 7:02:41 AM. by Stasy Borni. Forum started by Cermit
1190
Does polyester shrink when it's washed and dried?
Last answer on 1/23/2022 6:06:52 AM. by Celly Swehykol. Forum started by Rolly
9164
2902
Wall painting
2021
2972
Tips for Cement Paint
3175
2405
Tips for Aluminum Paint
Last answer on 1/16/2011 2:41:59 PM. by Swati Sharma. Forum started by Ar.chitra Tibrewal
2976
Need tips to decorate small(16X7 ft) drawing room
Last answer on 7/17/2020 2:14:48 AM. Forum started by SANJOY DHAR
10495
Last answer on 11/8/2021 4:04:08 AM. by S L Gupta (Civil Engg). Forum started by kveddy83
6222
Vastu and Brahmasthan
4723
How can we save money and less wasted through vastu tips at home
Last answer on 7/4/2020 2:01:06 AM. by Deepti. Forum started by shalini kulshreshtha
3966
date of birth 17 july 1968 confirm my vastu tips
Last answer on 11/30/2021 11:37:28 PM. by Johnchen969. Forum started by raghavendra
1922
Tips on Iron chukhat
Last answer on 8/5/2011 12:07:32 PM. by S L Gupta (Civil Engg). Forum started by Reena Sareen
3125
please tell me Tulsi plant where site situated in home as vastu tips
Last answer on 12/9/2011 5:33:11 PM. by Amit Hasija. Forum started by Ajay Rana
vastu tip for west fecing plot
Last answer on 1/22/2022 11:26:02 AM. by S L Gupta (Civil Engg). Forum started by priyanka sinha
30
Boyfriend/Girlfriend Vashikaran Specialist Tantrik Baba Ji 91-9056562757
Last answer on 1/6/2025 11:00:11 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:10 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:09 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:08 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:07 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:06 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:05 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:04 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:03 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:02 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:01 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 11:00:00 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 10:59:59 PM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 10:59:58 PM. Forum started by Pandit Sahil Sharma Ji
Dry distemper is water based wall paint and is more durable than color wash. It contains a glue and tinted powdered ch..
Tips for selecting Paint Color.
Selected paint colors may look different in different lights, both at daytime and at night. So, you should choose the ..
Surface
Tips for Synthetic Enamel Paint
Synthetic enamel paint is an oil based paint which is applied to provide better griping and long lasting finish. It is..
Plastic emulsion paint is a water based paint which gives soft effect to the walls. It is long lasting, washable and e..
Aluminum paint produces fine look, lustrous and superior quality finish on metal and wood. It is tremendously resistant
Surface
vaastu
