Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Tips for Laying RCC slab / roof
Wed Apr 08, 2015Total posts : 5
SREENIVAS K
SREENIVAS K
Topic: Tips for Laying RCC slab / roof
What will be the cost per sft if we make it RCC. side walls are of pillar construction. shed size is 55 x 91 ft.
The comment above talks about the article   "Tips for Laying RCC slab / roof"
Wed Apr 08, 2015Post  #1
It will cost you around 15 lac's.
Thu Apr 09, 2015Post  #2
john
john
Post subject: Tips for Laying RCC slab / roof
What quantity of cement, sand, and concret will be required for making RCC slab roof of 10ft x 10ft?
Thu Apr 09, 2015Post  #3
john
john
What quantity of cement, sand, steel and concret will be required for making RCC slab roof of 10ft x 10ft?
Sun Apr 12, 2015Post  #4
RCC Specifications
·         Shuttering shall be done using seasoned wooden boards of thickness not less than 30mm.
·         Surface contact with concrete shall be free from adhering grout, nails, splits and other defects.
·         All the joints are perfectly closed and lined up.
·         The shuttering and framing is sufficiently braced.
·         Nowadays timber shuttering is replaced by steel plates.
·         All the props of approved sizes are supported on double wedges and when taken out, these wedges are eased and not knocked out.
·         All the framework is removed after 21 days of curing without any shocks or vibrations.
·         All reinforcement bars conform IS specifications and are free from rust, grease oil etc.
·         The steel grills are perfectly as per detailed specifications.
·         The covers to concrete are perfectly maintained as per code.
·         Bars of diameter beyond 25mm diameter are bent when red hot.
·         The materials proportion should be as per the specifications of the concrete.
Number of Cement bags required for a specific cement concrete ratios
·         For cement concrete of ratio 1:1:2(1 cement:1sand/coarse sand:2graded stone aggregate) require 11no bags of 50kg.
·         For cement concrete of ratio 1:1.5:3 require 7.8no bags of 50kg.
·         For cement concrete of ratio 1:2:4 require 6 no bags of 50kg.
·         For cement concrete of ratio 1:3:6 require 4.25no bags of 50kg.
·         For cement concrete of ratio 1:4:8 require 3.2 no bags of 50kg.
·         For cement concrete of ratio 1:5:10 require 2.50 no bags of 50kg.
·         For cement concrete of ratio 1:6:12 require 2.25 no bags of 50kg.
Tue Jun 02, 2015Post  #5
D.C.tandon
D.C.tandon
My constructed area is 1800 s.f. let me know that 1-which type of shuttering is best for slab. 2-which beam is best latak or hazmi.
3087
9893
3753
3980
Roof leakage
4836
3966
cost estimater
191901
4953
1875
2407
2294
Last answer on 6/16/2021 11:37:22 AM. by S L Gupta (Civil Engg). Forum started by dnyanesh
2127
1783
Laying RCC slab
Last answer on 2/3/2015 11:57:39 PM. by SAROJINI. Forum started by SAROJINI
2090
1908
11102
2353
laying of roof
5811
3792
9885
2670
4628
4143
2865
5007
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Cupola installation tips
Tips for cupola installation
