Cracks
How To Repair Cracks
Thu May 06, 2010
suni dutt panwar
Topic: How To Repair Cracks
In my area there is Black cotton soil. so we fce a problem of cracks in newly or old building .we rectifed sevral times with many new compounds but same problem occurs with in two or three days even at time of const we removed all black cotton soil up to 1.5 mt deep refill that area with CNS soil . so please give suggestion to rectified all craks.
The comment above talks about the article
"How To Repair Cracks"
Thu May 06, 2010
Post subject: Reply-Repair Cracks
Dear Sunil,
Before doing any repair of cracks, make sure that the cracks are stabilized or not i.e. widening further. Remove broken bricks by scratching cement mortar from the joints gently. All loose materials should be cleaned from the portion by brushing and washing. Wet the surface 24 hours before doing the necessary repairs. Now lay RCC (cement conc. with 2 no steel bars) in one coarse height then laid the bricks tightly with fresh cement mortar with coarse sand in 1:4 ratios and repeat this process. Fill all joints around bricks with mortar tightly with the help of iron tools. Finish the area with plaster and do curing at least for 7 days. Employ expert mason for the repair work.
S.L.Gupta
Thu May 06, 2010
juhi
hi sunil dutt,
The cracks occur due to carelessness of contractor, mason, and ignorance of house owner and using of inferior materials in construction. If the cracks happen after all preventions, they must be repaired as soon as you observe them. Cracks threaten structural stability of the building.
These cracks are very dangerous and repaired immediately.
for further details you can read articles at
www.gharexpert.com
website.
and article link is:
http://www.gharexpert.com/articles/Cracks-1468/How-To-Repair-Cracks_0.aspx
http://www.gharexpert.com/category/1371/Cracks-0.aspx?CatID=1371
bye
take care..
Fri May 27, 2011
chotto
Post subject: How To Repair Cracks
One way of plaster repair is to use wire gauze on plaster surface which will hold the plaster and will let let it crack. I have use this technique in all most all the old plaster crack repair, which have given neat look as well.
Sat May 28, 2011
Post #4
MAHESH SALUNKHE
This article given me info. regarding repairs but i want to know what care should i taken to avoid repair works like rcc wall & brick wall joint.
Sun Jun 29, 2014
Post #5
Pradeep Ahi
Hi Sir, My house is 16 year old RCC construction and one of its central single bricked wall has a approx 8mm wide crack wich seems quite deep, please suggest a remedy
Cracks-Construction Questions (30)
1800
How to repair the suspension crack floor
Last answer on 2/4/2015 11:31:02 AM. by
BAURO
2336
Last answer on 2/4/2015 11:35:37 AM. by
Arun
2898
Last answer on 12/31/2020 2:07:59 AM. by
Karan
tkalaiva
2710
constraction details
Last answer on 1/1/2021 2:45:02 AM. by
ranvir kumar singh
2487
Exterior Wall Crack Repair
Last answer on 12/26/2011 7:13:39 PM. by
S. Kumar
2503
Last answer on 3/20/2012 2:39:36 PM. by
muqamil
2024
Industrial Maintenance
Last answer on 5/14/2021 10:32:21 AM. by
MarianneRolfe
1745
I have house in Ahmadabad. Since six months i am finding cracks in three walls.
Last answer on 5/30/2017 11:03:31 AM. by
Naimish Patel
3387
Last answer on 12/12/2012 2:44:23 PM. by
clarasmithh001
shabbir ali
6583
Last answer on 10/16/2014 12:42:44 AM. by
NV MANI
1886
Damp
Last answer on 4/4/2015 7:00:17 PM. by
Jag
1998
Last answer on 10/20/2017 9:52:15 PM. by
Arun
Arun
3370
Last answer on 7/3/2020 11:28:14 PM. by
Y Mitran
1599
Last answer on 7/3/2020 10:30:32 PM. by
dilip kumar
2731
Last answer on 4/8/2011 10:52:47 AM. by
Nikita
amartharaj
2712
Last answer on 9/13/2009 11:35:22 AM. by
Priti Arora
srinivasan
2248
ANY ONE TELL ME ABOUT THE BUILDING CRACKS
Last answer on 12/31/2020 2:31:49 AM. by
arun kumar sharma
3502
Last answer on 5/9/2010 4:02:07 PM. by
bhattkalpit
vrnavukarasu
1968
Last answer on 5/20/2010 8:30:01 PM. by
sudhir
3381
Recurring Cracks
Last answer on 1/26/2022 2:08:59 AM. by
Amar
4138
Last answer on 7/24/2021 12:31:40 PM. by
Girish
Rajan
5734
Last answer on 7/4/2020 2:50:48 AM. by
NV MANI
NV MANI
1592
How to renovate the broken staircase. please look the attachments.
Last answer on 4/25/2016 1:08:43 PM. by
chitta naik
1526
Cost for Polyurethene Grouting for Leakage from Flat Above
Last answer on 3/28/2015 6:24:30 PM. by
Unmesh
6881
Last answer on 10/3/2014 10:04:30 AM. by
azeez
2278
Last answer on 12/24/2013 11:25:05 AM. by
Animesh Das
2296
cracks in walls
Last answer on 9/4/2013 12:14:18 PM. by
Gagandeep
2059
Cracks in my new house
Last answer on 7/3/2013 12:47:10 PM. by
houseowner
3134
Last answer on 8/11/2012 7:47:58 PM. by
Amit
Amit
4035
Last answer on 4/29/2011 10:39:26 AM. by
sukhbir singh sandhu
Termite Damage Signs and repairing tips
Termite damage is a worst dream for any house owner. Termites eat wood and this affect almost every wooden product lik..
Tips for Cement Paint
Damp Proofing
