Fri Dec 16, 2016Total posts : 1
Pranav
Pranav
Topic: To replace existing slab with precast RCC slab.
           Can we replace  spalling RCC  slab with RCC precast slab in the house having no column.
How will it affect the cost of construction compare to traditional slab construction?
Sat Dec 17, 2016Post  #1
Dear Parnab,
         In my view you should go for traditional RCC Slab there is no much differance in cost and it will remain safe in long run.
2294
Last answer on 6/16/2021 11:37:22 AM. by S L Gupta (Civil Engg). Forum started by dnyanesh
2407
3753
4953
2581
Looking for Precast Engineers, Precast Compound Wall and Precast Slabs
Last answer on 5/12/2014 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by nell
2525
1981
Last answer on 10/27/2015 10:43:31 PM. by JAI PRAKASH. Forum started by Baba Dedge
4010
labor rate for RCC work
2866
Steel calculation
2975
1460
4836
5861
7834
Rcc staircase rates
Last answer on 3/18/2016 4:13:47 PM. by S L Gupta (Civil Engg). Forum started by Shabbir shaikh
3783
difference b/w colum, beam and RCC slab
Last answer on 7/25/2013 5:09:29 PM. by LAKWINDER. Forum started by paresh
3980
Roof leakage
Reasons of dampness
Centering
Garden
Garden Path Ideas
