Home -> Forums -> Construction -> Interior Lifestyle -> Top 10 mistakes in stairs design
Thu Dec 24, 2009Total posts : 4
M K
M K
Topic: Top 10 mistakes in stairs design
Good information but you did not given the information about the "directional-turning" of stairs for duplex type or traditional type home seperately. Kindly through more light over our quries, please. Thank you.
The comment above talks about the article   "Top 10 mistakes in stairs design"
Tue Jan 05, 2010Post  #1
Post subject: Reply-Top 10 mistakes
Dear MK
Please find below  the information about the "directional-turning" of stairs for duplex type or traditional type home:
The simplest form stair is the straight flight of stairs, without any winders nor landings. It is not often used in modern homes due to following effects.
  • The upstairs is directly visible from the bottom of a straight flight of stairs.
  • It is potentially more dangerous in that a fall is not interrupted until the bottom of the stairs.
  • The straight flight requires enough space for the entire run of the stairs.
However, a straight flight of stairs is easier to design and construct than one with landings. Additionally, the rhythm of stepping is not interrupted in a straight run, which may offset the increased fall risk by helping to prevent a misstep in the first place.
Most modern stairs incorporate at least one landing. "L" shaped stairways have one landing and usually change in direction by 90 degrees. "U" shaped stairs may employ a single wider landing for a change in direction of 180 degrees, or 2 landings for two changes in direction of 90 degrees each. Use of landings and a possible change of direction have the following effects:
  • The upstairs is not directly visible from the bottom of the stairs, which can provide more privacy for the upper floor.
  • A fall can be arrested at the landing.
  • Though the landings consume total floor space, there is no requirement for a large single dimension, allowing more flexible floorplan designs
For larger stairs, particularly in exterior applications, a landing can provide a place to rest the legs.
Sun Jul 04, 2010Post  #2
K C MAHAPATRA
K C MAHAPATRA
Post subject: Top 10 mistakes in stairs design
KINDLY GIVE SOME IDEAS FOR UTILISATION OF SPACE BELOW STAIRCASE AS PER VASTU. CAN IT BE USED FOR A TOILET.
Fri Jul 27, 2012Post  #3
Jagajothi
Jagajothi
STAIRCASE ARTICLE IS VERY USEFUL, SMALL THINGS ALSO VERY HELPFUL TO OUR DAILY LIFE ANOTHER THING THE STAIRCASE IN CORNER SIDE WHICH CLOSE CEILING IS ADVISABLE OR NOT, EXAMPLE STAIRCASE IN SOUTHEAST CORNER WHICH CLOSE CEILING AFFECT OUR WEALTH EXPECT YOUR GOOD ADVICE,IS IT AGNEYa cut/ HOW CAN WE SOLVE IT. .
Mon Aug 12, 2013Post  #4
jk
jk
usefull tips for learners
Interior Lifestyle-Construction Questions (23)
2930
Last answer on 12/31/2020 2:12:06 AM. by Ramachandran.P.V. Forum started by Johnny Valencerina
2580
Last answer on 10/3/2021 3:08:13 AM. by swamy. Forum started by richa
2977
Last answer on 12/31/2020 2:26:35 AM. by rajendrakumar. Forum started by mary cecil
3029
I have a Kitchen of 6'' * 10"" Plx suggest some kitchen designs
Last answer on 7/3/2020 10:48:15 PM. by Nisha Batra. Forum started by Sarbani Biswas
4134
Last answer on 7/3/2020 10:23:02 PM. Forum started by V.BASKER
2306
how can we adjust sofa cum bed and a sofa set as a living room in 12'-3"*13'-10"
Last answer on 4/4/2012 9:28:10 PM. Forum started by smiley oberoi wahi
1989
best designs for external stair cases
Last answer on 9/20/2021 12:33:21 PM. by JAI PRAKASH. Forum started by rambo fernandes
1374
I want external stair design
Last answer on 4/2/2016 11:25:11 AM. by S L Gupta (Civil Engg). Forum started by pushpak
1652
Plan for 10 by 55 size plot
Last answer on 7/19/2016 2:37:21 PM. by AR. HIMANSHU PHOGAT. Forum started by pankaj
2622
I want false celing designs of bedroom for room size 10" X 12.5".
Last answer on 4/3/2021 12:41:20 AM. by Ar. Manoj Ralen. Forum started by vinod
1242
we built house before 10 years but stairs were on issian notrhwest side which is
Last answer on 2/21/2011 2:41:53 PM. by sabina vanjani. Forum started by SANDHYA DWIVEDI
2104
Last answer on 1/28/2011 6:29:20 AM. by Nikita. Forum started by madhu
1737
I have design of stairs from south to north is it correct as per vastu or reqire
Last answer on 1/2/2014 3:37:10 PM. by S L Gupta (Civil Engg). Forum started by Dipesh
1861
23X60 WEST FACING 3 BED ROOM DOBOULE FLOOR HOUSE DESIGN AS PER VASTU UP STAIR FR
Last answer on 2/19/2019 11:24:30 PM. by S L Gupta (Civil Engg). Forum started by RAJANI KANTA PATRO
3623
1815
My house which is facing frony wall is facing North but while construction by mi
Last answer on 7/23/2011 7:19:07 PM. Forum started by Manjeet singh
2466
3176
Kitchen design mistakes
Last answer on 7/3/2020 9:07:47 PM. by manjulaagarwal1955. Forum started by kcantony
6693
Need a design for My ceiling
Last answer on 2/24/2022 2:27:55 AM. by taroset. Forum started by amar
1970
Last answer on 9/23/2021 1:44:52 AM. by seema tyagi. Forum started by SINDHU VASU
2589
Concrete Decor
Last answer on 12/31/2020 2:08:15 AM. by LULU. Forum started by manoj
2631
Interior Decorating Ideas
Last answer on 4/17/2011 5:06:47 PM. by Nikita. Forum started by pattipatisrinivasulu
1941
Staircase railings
Last answer on 5/18/2010 8:04:17 PM. by Vinutha. Forum started by Manju
How to Design Stairs?
How to Build Stair Steps
Safety
Safety Tips For Stairs
Utilization
