Home -> Forums -> Construction -> Waste Water Drainage -> Traps - Types and Uses
Sun Jul 03, 2011Total posts : 1
SHAMS
SHAMS
Topic: Traps - Types and Uses
1) All plumbing fixtures such as wash basin, bath tubs etc. have their own p traps, so why is it necessary to provide a gully trap outside the house before final connection of the waste with the sewage manhole? 2) Must a vent be provided downstream of the gully to prevent the seal of the gully itself?
The comment above talks about the article   "Traps - Types and Uses"
Mon Jul 04, 2011Post  #1
Dear Shams
        In a two pipe system, the waste pipe carrying discharge from the wash basin, sinks bath etc is connected to the sewer through gully trap so that foul gas from the sewer do not find an entry  in to the house. It is deep seal trap provided on the external face of bath room and kitchen wall.It also prevents the ingress of the coacroaches and insects from the sewer line in to the waste pipe system carrying sullage.
Waste Water Drainage-Construction Questions (25)
1729
WHICH TRAP IS USED FOR INDIAN AND EUROPIAN W.C.
Last answer on 7/30/2014 9:21:40 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
2024
what traps should be used for wash basins and kitchen sinks, enclosed or open?
Last answer on 3/3/2014 12:22:33 PM. by S L Gupta (Civil Engg). Forum started by neelam rathi
2827
Last answer on 2/13/2012 3:19:03 PM. by PR Jawahar. Forum started by pallubc2
2686
commode type and flush type
1781
How I can buy this s trap
Last answer on 6/8/2013 6:14:17 PM. by Navneet Jharia. Forum started by joemon
1807
what is the diffrence between s-trap and p-trape
Last answer on 7/29/2014 2:29:59 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2487
2088
about window glass
Last answer on 11/17/2014 6:11:13 PM. by JAI PRAKASH. Forum started by narendra adkine
1599
do bottle traps get clogged easily and are they easy to clean?
Last answer on 7/18/2014 12:10:12 PM. by seema tyagi. Forum started by neelam rathi
2169
Last answer on 4/18/2010 4:48:04 AM. by SRPRAVI. Forum started by manoj gupta
3090
What type primer and paint should be used for concrete window and door frames?
Last answer on 6/5/2017 12:48:40 PM. by S L Gupta (Civil Engg). Forum started by vinu
9106
Bathroom with no sunken slab
Last answer on 7/3/2020 9:35:17 PM. by rinondavid. Forum started by Swaroop
18395
2966
3665
1973
water dampness
Last answer on 11/13/2014 6:26:53 PM. by JAI PRAKASH. Forum started by sunder
2051
PVC windows
13065
what is IPS type waterproofing
Last answer on 9/23/2021 2:31:50 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2623
modern type pooja room
Last answer on 4/2/2014 2:14:53 PM. by S L Gupta (Civil Engg). Forum started by raj
2034
whats remedy fr wall dampnass
Last answer on 2/25/2022 7:03:51 AM. by helloaarti21. Forum started by rakesh chopra
3301
2767
2392
Sewage and drainage lines
2005
please help....slow draining in the bathroom
Last answer on 7/4/2020 2:24:02 AM. by mvnisha. Forum started by mvnisha
2509
Traps
Proper drainage system is essential for waste water of the house. Traps and water seal are an important part of draina..
Skylight
Types of Cement
Hard
Cedar Wood
