Home -> Forums -> Construction -> Finishing -> Triangle House roof
Triangle House roof
Fri Jan 30, 2015Total posts : 1
tayyab
tayyab
Topic: Triangle House roof
How can we make Triangle roof house? what does it called and what what we have to arrange for it.
Mon Feb 02, 2015Post  #1
Dear Tayyab
           You want to construct triangular roof of your house. For this you should make shuttering triangular.
Finishing-Construction Questions (36)
1187
How to design to construct a home on triangle plots of small bit?
Last answer on 7/3/2020 10:58:51 PM. by S L Gupta (Civil Engg). Forum started by Ajay
4647
12306
What are the advantages of Kota stone flooring?
Last answer on 6/27/2010 4:58:24 PM. by Ramen Roy. Forum started by harsh
1673
Land piece not belonging to me but accessible only to me
Last answer on 4/25/2014 7:01:51 PM. by Navneet Jharia. Forum started by awdhesh
1325
I have a triangle shape plot facing east. Can the corners of triangle be removed
Last answer on 11/6/2011 7:41:08 PM. Forum started by urmila
2637
Converting tiled roof to RCC roof
Last answer on 6/19/2015 7:57:21 PM. by G K Rao. Forum started by G K Rao
2267
RCC roof on other than pillar
Last answer on 11/26/2015 3:34:20 PM. by S L Gupta (Civil Engg). Forum started by Binoy Rabha
8419
Roof Beam crack
2798
hai my house is constructed 7 years ago, now the roof slab is leaking year by y
Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya
2210
3271
Roof Concrete Strength
1647
2158
1837
1791
2849
2370
Roof construction
2018
Last answer on 2/2/2022 11:26:31 PM. Forum started by manjunath
2592
Elevations Required
Last answer on 2/2/2022 10:53:23 PM. Forum started by gangula
3202
Cracks on the walls
Last answer on 1/14/2022 10:40:04 AM. by S L Gupta (Civil Engg). Forum started by devjani roy kashyap
2897
Wall painting
2083
CEMENT PANI - Plaster Works
3870
Last answer on 1/14/2022 4:09:54 AM. by S L Gupta (Civil Engg). Forum started by Sameer
2333
tiles or marble
Last answer on 12/4/2021 5:12:27 AM. by S L Gupta (Civil Engg). Forum started by aammiitt
3536
stone wall cladding
1515
help
1542
POP OR GYPSUM
10933
Lappam vs Wall Putty
1932
Last answer on 3/5/2016 9:18:00 PM. by JAI PRAKASH. Forum started by raj
1834
1961
1881
Final Handover
Last answer on 5/14/2014 2:15:33 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
2118
2569
Thermal Insulation of Home
Last answer on 3/29/2010 7:23:40 AM. by abhijeet pawar. Forum started by akkulshrestha
Cooper
Green
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
