Home -> Forums -> Construction -> Cement -> Type of Cement
Type of Cement
Fri Apr 29, 2011Total posts : 1
sumit dua
sumit dua
Topic: Type of Cement
I am going to construct house on 166sq yard plt with basement, ground floor, first floor and second floor.
I am confused which cement type to use: 43 Grade or 53 Grade
Although 53 Grade cement has high strength but it's prone to have cracks. Please advise.
Also what cement type is expensive out of above ?
Mon May 02, 2011Post  #1
Dear Dua
For construction of house 43 grade cement is better. For more detail you should see detail in the link given below.
http://www.gharexpert.com/articles/Cement-1470/Types-Cement_0.aspx
2872
Types of Cement
2409
what are these 3 types
1789
Dear sir/madami am building a house in coastal part of goa.need advice from expe
Last answer on 10/11/2015 8:43:58 PM. by JAI PRAKASH. Forum started by prasad K
2307
Cement selection
Last answer on 10/31/2012 10:53:57 AM. by amzad. Forum started by amzad
2849
Natural Stone Design
Last answer on 2/20/2022 12:24:13 AM. by leelindsey. Forum started by Swarup Kumar Dey Choudhury
2325
Materials
3791
4209
Selection of cement ..
1659
Last answer on 7/15/2017 12:48:17 AM. by S L Gupta (Civil Engg). Forum started by Frank lun ngaihte
1763
1457
2695
1923
3651
2962
18382
1741
4371
Ready Mix Concrete
1669
Cement requirement
1784
RAW MATERIAL
2527
RCC Slab -Curing
2325
Materials
23818
Last answer on 2/17/2021 4:49:34 AM. by S L Gupta (Civil Engg). Forum started by vinu
2872
Types of Cement
2515
Cement
2736
Per Square
Last answer on 6/23/2019 11:56:29 PM. by S L Gupta (Civil Engg). Forum started by kiran kumar 3k
1282
1989
Cracks in concrete roof
1241
Last answer on 5/26/2016 12:44:58 PM. Forum started by SUNIL KUMAR
1741
2265
Cement selection
1876
Economical cement brand
Last answer on 2/22/2015 7:02:19 PM. by Bhuwan. Forum started by Bhuwan
2903
Cost of Cement Plaster
1856
Last answer on 4/11/2014 2:04:43 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
2484
Cement and Grades
Last answer on 6/13/2013 2:45:08 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
3040
2435
Past Prices
Last answer on 11/23/2011 10:23:47 AM. by ravi at Dalmia. Forum started by Hemanth
Types of Cement
Types of cupola
Let's find details about types of cupola in this writeup
Styles of dormer
This article contains the list of dormer styles.
Types of arch
Kitchen Cabinets
Type
Aluminum
Aluminum door finishes types
There are variety of options for aluminum door finishes available. Let’s get to know the types and recommendation for..
What are various types of panel doors?
Single panel, Double Panel, Three Panel, Six Panel doors........
Which are various types of vinyl flooring?
Two types of vinyl flooring such as inlaid and printed............
Which are various types of pointing according to designs?
Flush Pointing,Deep Variety ( Weathered and Struck ) Pointing,Raised Pointing
