Thu Jan 21, 2010Total posts : 14
Muhammad Rizwan
Muhammad Rizwan
Topic: Type of Steel Bars
site has good technical information and has best information for site engineers
The comment above talks about the article   "Type of Steel Bars "
Fri Jan 29, 2010Post  #1
Ajay Dua
Ajay Dua
Post subject: Agreed
Yes, I am totally agreed with you. This site has great potential to serve both, professionals and a person constructing or renovating own home.
Wed Mar 17, 2010Post  #2
Varughese K.P.
Varughese K.P.
Post subject: Type of Steel Bars
I want my professional area want to develop.
Thu Aug 12, 2010Post  #3
K Rajendra Prasad
K Rajendra Prasad
I am planning to construct a house with ground plus two floors. probably 16 pillers may be required for it. can any one plz suggest me dia of steel bars required for me.
Fri Oct 15, 2010Post  #4
SS Malhotra
SS Malhotra
which is the best location for over lapping of steel bars in RCC columns. If the lapping comes inside the beam or slab, is it considered 100% normal and safe location
Thu Dec 16, 2010Post  #5
vinay
vinay
after how many days of lanter we shall start for the second floor construction
Thu Dec 30, 2010Post  #6
Ashraf
Ashraf
i need information regarding how much steel required in slab/beam/col./footing or in any R.C.C works ,if we have the quantites of concreate.
Tue Jan 04, 2011Post  #7
Nick
Nick
Built up area = 16*22 ft Queation1: How many RCC pillars to hold up Ground+First+Second Floors? Queation2: What should be pillar thickness? Queation3: How many steel bars per pillar? Queation4: What should be steel bar thickness?
Sat Jan 15, 2011Post  #8
tajuddin
tajuddin
Kindly show the overlaps in the following Join 1 inch diameter to 1 inch diameter bars for COLUMNS (Overlap= ---- inches) Join 3 / 4 inch diameter to 3 / 4 inch diameter bars for COLUMNS (Overlap= ---- inches) Join 1 inch diameter to 3 / 4 inch diameter bars for COLUMNS (Overlap= ---- inches) Join 3 / 4 inch diameter to 1 / 2 inch diameter bars for COLUMNS (Overlap= ---- inches) & Join 1 inch diameter to 1 inch diameter bars for BEAMS (Overlap= ---- inches) Join 3 / 4 inch diameter to 3 / 4 inch diameter bars for BEAMS (Overlap= ---- inches) Join 1 inch diameter to 3 / 4 inch diameter bars for BEAMS (Overlap= ---- inches) Join 3 / 4 inch diameter to 1 / 2 inch diameter bars for BEAMS (Overlap= ---- inches) Similarly Join 1 inch diameter to 1 inch diameter bars for SLAB (Overlap= ---- inches) Join 3 / 4 inch diameter to 3 / 4 inch diameter bars for SLAB (Overlap= ---- inches) Join 1 inch diameter to 3 / 4 inch diameter bars for SLAB (Overlap= ---- inches) Join 3 / 4 inch diameter to 1 / 2 inch diameter bars for SLAB (Overlap= ---- inches) Clear a GENERAL FORMA for the overlaps. Kindly E MAIL as soon as possible. Address=KARACHI, PAKISTAN E MAIL=tajuddin.charania@gmail.com
Sat Jan 15, 2011Post  #9
tajuddin
tajuddin
Tue May 31, 2011Post  #10
sheotaj singh
sheotaj singh
Hi I am planning to construct Ground floor and upto second floor house . Total covered area is 900 sqft and 12 pillars may be require for it. Kindly let me know the thickness (dia)of steel bars for coloumn and beam
Sun Jun 26, 2011Post  #11
K.V Reddy
K.V Reddy
I am going to to make a house, ground + 2 floor, i need a footing design, area is 1500 SQft, residential house, can anybody help me, particularly i am looking, foundation, footings steel design
Wed Mar 27, 2013Post  #12
Helena Dorbor
Helena Dorbor
please email all the prizes for steel.
Wed Jun 03, 2015Post  #13
moeen akhter
moeen akhter
great web site very informative informationcells.com
overlap length to steel
2904
RCC Roof
1307
1637
3063
steel formula
Last answer on 4/16/2014 8:05:15 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
1827
2039
2711
2306
2037
13771
3112
1279
1258
Is HYSD steel bars still used for construction. Do they meet the safety standard
Last answer on 1/10/2019 12:18:04 AM. by S L Gupta (Civil Engg). Forum started by rinu
1533
1179
3747
Last answer on 9/17/2013 12:55:48 PM. by ijazulhaq. Forum started by Tanmoy Mukherjee
1700
Roof related
Last answer on 3/5/2016 10:32:12 PM. by JAI PRAKASH. Forum started by Pooja
2688
Last answer on 4/26/2021 10:00:27 AM. by mohamed. Forum started by Sanjeev Thakur
SoLuTioN:fOR tO 91- 8769373431KaLa jaDu VaSHiKArAn SPeCiAlIsT
Last answer on 12/27/2024 11:23:30 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:23:24 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:23:18 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:23:11 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:50 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:44 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:38 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:33 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:26 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:20 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:14 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:22:05 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:47 PM. Forum started by rupeshji
36
Last answer on 12/27/2024 11:21:38 PM. Forum started by rupeshji
49
Last answer on 12/27/2024 11:21:31 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:25 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:19 PM. Forum started by rupeshji
20
Last answer on 12/27/2024 11:21:12 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:21:03 PM. Forum started by rupeshji
Last answer on 12/27/2024 11:20:57 PM. Forum started by rupeshji
Type
HSD
TMT
Precautions
Dining
Dining Chairs and Bar Stools
