Home -> Forums -> Construction -> Foundation -> Types of Soil
Types of Soil
Sat Aug 15, 2015Total posts : 1
gpeter
gpeter
Topic: Types of Soil
What are the types of soil in India as regards building works?
In our area, they have classified soil type as
A
Most sand and rock sites, with little or no ground movement
S
Slightly reactive clay sites, with only slight ground  movement
M
Moderately reactive clay or silt sites which can experience moderate movement
H
Highly reactive clay sites, which can experience high ground movement
E
Extremely reactive sites,
P
Soft site, which includes soft soils, such as soft clay or silt
It will be good if someone can compare and contrast Indian soil types with the above.
Thanks, Gerard
Mon Aug 17, 2015Post  #1
 It is matter of research.
1827
foundation
Last answer on 10/5/2014 1:20:44 PM. by SANJAY DUSANE. Forum started by nitu
2619
Last answer on 4/19/2017 4:35:06 PM. by B Thakar. Forum started by tareq
1891
Foundation Digging Help
Last answer on 1/25/2021 8:47:56 AM. by Shivaraj. Forum started by Shivaraj
2321
4126
1837
foundation
Last answer on 10/18/2013 4:09:57 PM. by S L Gupta (Civil Engg). Forum started by yu nandar
2994
14599
2680
My House design
Last answer on 10/15/2014 8:31:38 AM. by SANJAY DUSANE. Forum started by naresh
2749
2647
How To Repair Cracks
Last answer on 5/6/2010 12:31:22 AM. by . Forum started by suni dutt panwar
3651
18382
2962
114
Last answer on 1/30/2011 9:45:38 AM. Forum started by Girish
2477
PL. SEND FLAT TYPE INTERIOR INFORMATION WHICH ARE USEFUL FOR MID SEGMENT FLA
Last answer on 5/16/2010 2:04:24 AM. by amit yadav. Forum started by shweta
2710
could you send me some more good designs not satisfied with this type of pop cei
Last answer on 6/23/2021 6:18:33 AM. by Richa Shangvi Interior decorator. Forum started by maya
3268
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2202
new house
2821
building a house
1991
Construction Agreement
3089
Foundation
2272
Foundation
1476
10047
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2459
2467
Saria and cement
3656
Wall Thickness
2678
3179
13267
Steel Type
Which are various brands of pipes for drainage of soil water?
Brands of pipes for drainage of soil water-C.I. Pipes-CIC..........
Preliminary
Types of cupola
Let's find details about types of cupola in this writeup
Styles of dormer
This article contains the list of dormer styles.
