Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Sun Jul 01, 2012Total posts : 2
Lynda
Lynda
Topic: Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde brick and I really dont like it. I dislike painted brick almost as much so Id like to know if I can plaster over the brick and if so how do I go about it
Thu Jul 05, 2012Post  #1
Swati Satija
Swati Satija
Dear Lynda
Please check the link given below. It contains some pictures of fireplace decoration. May these pictures help you.
http://www.gharexpert.com/Home/show_multiple_images.aspx?Ind=9&find=fireplace
Swati
Mon Jul 09, 2012Post  #2
Ar. Manoj Ralen
Ar. Manoj Ralen
Dear Lynda,
As you have not attached the picture so I don;t know the material of your brick fireplace but you can use the info below.
1) You should be able to plaster over the bricks or brick tiles.
2) I don;t think it would be the case but still if ceremic tiles with brick finish are used then you would have to remove that material before plastering.
thanks
4057
2866
Bricks
3993
2350
3457
2876
1815
2993
3082
9197
2153
2523
1341
2422
2030
Need to strengthen brick wall and brick pillar house
Last answer on 5/3/2016 12:24:38 AM. by JAI PRAKASH. Forum started by Sudipto Choudhury
2417
2018
24
28
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Bedding
Bedding Cover
