Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Usage of M-Sand in Bangalore
Mon Aug 10, 2015Total posts : 1
Rajiv
Rajiv
Topic: Usage of M-Sand in Bangalore
I am constructing a house in Bangalore and the sand price seems to be shooting up. My engineer and architect both suggested to use M-Sand (manufactured sand) which they say has been certified by lot of structural engineers.
Can you please guide me and let me know if I can really use it?
The pending works are:
- first floor brick work (wall)
- first floor roof
- plastering (my engineer doesn't want M-Sand for plastering)
- compound wall
etc.
Thank you!
Raj
Thu Aug 13, 2015Post  #1
Yes you can use it as suggested.
1993
coarse aggregate
3682
1610
1747
1443
2218
hi,please could you give me an address in bangalore where i could buy charater c
Last answer on 8/1/2012 4:09:38 PM. Forum started by Lully Gibbons
3913
2287
Sand units
1674
Sand units
1508
Sand units
2080
river sand
2728
28802
latest price of building materials in bangalore
Last answer on 10/10/2010 12:44:43 PM. by rudresh. Forum started by manjuks
11392
WHAT IS TH PRICE OF TEAK WOOD IN BANGALORE
Last answer on 12/28/2011 10:07:52 PM. by S L Gupta (Civil Engg). Forum started by ramesh s
2368
can any one tell me the price range of granites in bangalore
Last answer on 7/18/2012 12:55:23 PM. by S L Gupta (Civil Engg). Forum started by padmaraju
2243
Steam Bath for Your Dream Home
Last answer on 1/24/2012 3:17:51 PM. by Ormond Max. Forum started by 6222011111047
4249
any gud designer for modular kitchens in bangalore
Last answer on 7/4/2020 2:23:27 AM. by Dinesh Mittal. Forum started by pv rao
2543
Bye Law
10088
5739
3764
9871
2653
4607
4126
2837
5194
4935
3633
4045
1836
2777
2589
2322
2441
2624
1795
3588
6223
Swimming
Swimming Pool Filters
Through
How To Repair Cracks
