Home -> Forums -> Construction -> Brick work -> Using M-Sand and Concrete bricks
Sat Oct 08, 2011Total posts : 1
Vinod
Vinod
Topic: Using M-Sand and Concrete bricks
Is there any difference between river sand and m-sand in therms of quality and durability? Can we safely replace river sand with m-sand for all house construction work including pillar foundation and ceiling? The price for river sand goes up and still many contractors recommend river sand over m-sand. Is it only a strategy to force the clients to buy river sand in over priced black market? As the M-sand also comes under different brand names and different grades, could you provide any guide lines to choose the best at different stages of construction?
Now a days Concrete Bricks are used in most of the multi-storeyed pillar structure buildings but still clay bricks are preferred in house construction work. So, is it bcoz concrete bricks are in low quality in load bearing capacity compared to clay bricks? Do you recommend using concrete bricks for house construction? If yes, any guide lines for choosing quality concrete bricks? please help.
Mon Oct 10, 2011Post  #1
Dear Vinod
 In general the sand particle should be coarser and have minimum silt contents. The silt contents should not be more than 4%.
The quality of the sand has more impact on the strength of the structure inspite of the quantity of the cement used.
1) If there is more silt in coarse sand, the strength of cement mortar is reduced from 1 % to 30%.
2) If you take best quality coarse sand, it will give maximum strength
For more detail see article link given below.
1767
1460
2993
2153
2243
sand alternate for concrete
1625
2308
is m sand adviceable toconstructwith bricks
Last answer on 1/23/2016 8:42:33 PM. by JAI PRAKASH. Forum started by ajitkumar
3433
3272
For Estimate
3010
M-Sand for Plastering
1846
1728
Last answer on 11/6/2015 12:41:03 AM. by JAI PRAKASH. Forum started by Techman
2064
cement : sand:stone ratio
1885
What is the function of granite in concrete conpare to sharp sand?
Last answer on 5/27/2011 4:14:40 AM. by S L Gupta (Civil Engg). Forum started by onims
3495
Robo Sand for Brickwork
2523
2521
construction const
3495
3669
wals
3264
compound wall
21875
3280
Bedroom Wardrobes information
2246
2206
1494
1965
1732
2224
2523
1502
1910
Brick or ACC block
1654
2153
1702
4688
Brick wall on RCC slab
3929
2618
Concrete Mix Ratio
Hard
Using
