Raw Material
Using old bricks for construction
Thu Nov 03, 2011
Col MP Singh
Topic: Using old bricks for construction
I have a old house (25 years old) built on a 500 sq yds plot. I intend to demolish the house and build a new one on that site.
My question is - should I use the old bricks. Can the malba be also used for filling the foundation and raising the plinth level. Or, is it better to use new bricks etc?
Please advice
Tue Nov 08, 2011
susandixon
The bricks are perfect to use for a strong foundation, if I were you I would use new bricks just to be sure that t he bricks have are still in good condition.
3436
sunmica
Last answer on 12/6/2012 10:52:25 PM. by
shailesh kumar singh
tanaji
4647
Last answer on 11/4/2021 8:45:13 PM. by
Prem Kant Mishra
Last answer on 6/7/2017 12:17:49 PM. by
Prem Kant Mishra
2991
1814
Last answer on 10/3/2016 1:56:08 PM. by
ajit kumar
2706
type of brick
Last answer on 12/5/2013 11:14:47 AM. by
neelam rathi
6450
Last answer on 10/8/2011 10:00:53 AM. by
Vinod
2587
mortar thickness in brick joints in foundation
Last answer on 8/23/2011 8:47:15 PM. by
ahsan
2507
Last answer on 12/27/2014 3:24:08 PM. by
Last answer on 1/25/2022 12:11:46 AM. by
Muhammad
1272
Last answer on 7/4/2020 4:24:08 AM. by
Anu Mohan
2835
Compound Wall Construction
Last answer on 11/20/2012 3:25:21 PM. Forum started by
honnappabr
13650
Last answer on 1/18/2022 1:46:41 PM. by
Bronx
honnappabr
2931
FLY ASH BRICKS
Last answer on 6/27/2009 12:07:21 PM. by
Kranap
mamta
2095
Red Exposed Brick
Last answer on 12/8/2014 10:03:59 PM. by
awdhesh
2196
Last answer on 12/31/2020 8:58:35 PM. by
Joseph Santhosh
2521
construction const
Last answer on 7/3/2020 11:20:15 PM. by
tushar
5187
Can the "Gypsum Stucco Plaster" be used directly on an unplastered wall??
Last answer on 3/25/2011 1:57:52 PM. by
Nikita
Amogh Desai
3075
RCC roof
Dinesh Bhadu
1971
Marriage hall construction
chandana kumar
2537
Function Hall
Last answer on 6/14/2021 7:48:53 AM. by
Janette
Mark Paraon
4201
Mohan Bhagwat
11102
Last answer on 3/16/2021 12:44:03 AM. by
Mohan
2189
Last answer on 11/19/2020 1:18:18 AM. by
Aamir
2037
Estimate
Last answer on 7/3/2020 10:09:08 PM. by
amzad
amzad
3072
Steel
Last answer on 7/2/2020 10:08:44 PM. by
EvaR
use of tmt bar
sonu.211
1642
work turned out by labour
Last answer on 5/15/2017 1:35:22 PM. by
carola braats
2456
estimate
raj
1762
mohd asif
2991
3606
Last answer on 5/26/2016 3:18:53 PM. by
naresh
1943
Cost of Steel construction
Last answer on 4/22/2016 11:27:17 AM. by
VikasUmate
1612
Last answer on 12/17/2015 2:49:59 PM. by
sushantsah
2135
READY MIX PLASTER
Bimlendra Jha
1864
Last answer on 3/1/2015 8:14:42 PM. by
baskar
2223
zero slump concrete
Malik Usman
How to Paint Old Furniture
Types of Cement
