Home -> Forums -> Vastu -> Dining -> Vasthu plot size
Vasthu plot size
Sun Feb 03, 2013Total posts : 3
subbu_pl
subbu_pl
Topic: Vasthu plot size
I am planning to buy plot with size of 34 * 19 sq ft. 34 is north side and 19 is at west side. Will it be satisfies vastu for residential construction for own purpose. Also it is corner plot.
Sun Feb 03, 2013Post  #1
Devendra
Devendra
Yes you can plan the house as per the Vastu 100%
Tue Feb 05, 2013Post  #2
Hitesh Bhoi
Hitesh Bhoi
Post subject: instruction as per my experience .
hello , This is Hitesh an interior designer and also an undergraduate architect student instruct you the required plot  that you have given  34 / 19 is absolutely a good  plot area according to vastu  and the corner plot is the best mentioned area to be constructed as it have more spacious area and you can do your own gardening or any future constructed rooms if requred . so go for it . any querries related to housing plans or interior designs feel free to conract me on my email id hiteshbhoi31@yahoo.com or hiteshbhoi21@gmail.com . thank you.
Fri Feb 08, 2013Post  #3
Pavan
Pavan
Post subject: Vastu plot size
Hello Subbu,
Can you help with the layout of your new plot that you are planning to buy?. Also pls consider the slopes, roads, buildings around this plot, surroundings, road hittings, Municipal drainage chambers/manholes temples, Wells, Bore wells, in adjoining plots before making a decision to buy a plot.
Doing remidies after buying the plot and considering the above factors before buying a plot there is a huge difference in that.
Thanks & Regards
Pavan Matkar (pmatkar@gmail.com
Wastu Wimarsh
Dining-Vastu Questions (27)
11518
24*50 east facing plot i want lan with vasthu
Last answer on 11/28/2016 1:34:36 PM. by S L Gupta (Civil Engg). Forum started by Kranthikumar
1077
west face plot vasthu
Last answer on 9/26/2018 12:11:11 AM. by S L Gupta (Civil Engg). Forum started by uday
19871
16/45 plot size....give a best plot map
Last answer on 10/27/2016 2:18:00 PM. by Beenu Phogat. Forum started by piyush ji srivastav
1639
Last answer on 10/5/2015 2:52:54 PM. by S L Gupta (Civil Engg). Forum started by Kuldeepsingh
29049
2105
house construction plot size 34x28
Last answer on 7/20/2015 11:59:33 AM. by seema tyagi. Forum started by aziz
1944
Last answer on 7/20/2015 11:56:05 AM. by seema tyagi. Forum started by aziz
2341
my plot is 25*23 size vastu plan and frunt elevation degiene in groud floor my
Last answer on 2/7/2016 10:36:39 PM. by JAI PRAKASH. Forum started by sanjay sinha
1448
Kindly help me for making floor plan for west facing plot of 27x60 feet with on
Last answer on 4/5/2017 12:49:06 PM. by S L Gupta (Civil Engg). Forum started by DC SRIVASTAVA
2135
i want to buy a plot south face of 23 feet by 50feet, pl suggest one house plan
Last answer on 7/3/2015 3:33:15 AM. by JAI PRAKASH. Forum started by seshagiri
2835
I am constructing a house in north face plot please send right position of septi
Last answer on 3/31/2012 8:53:58 PM. by J J Gupta. Forum started by J J Gupta
4757
my name is shrinivas, as per vasthu how to find which area is the best for buyi
Last answer on 11/24/2009 10:10:44 PM. by Mani . Forum started by shrinivas
2282
3425
1988
please advise design for plot size 40x54.5 feet
Last answer on 8/17/2011 3:06:02 PM. Forum started by rupesh
2257
Last answer on 8/17/2011 3:36:23 PM. Forum started by k p singh
3607
what will be the best plan duplex in 14X50 plot size
Last answer on 2/9/2012 8:22:29 PM. by Shama. Forum started by Shama
9038
i want to designe 30x30 size plot
Last answer on 6/2/2012 6:20:05 PM. by Swati Satija. Forum started by sharma
3577
north facing plot map size 25*50sqare yards
Last answer on 6/15/2013 8:58:08 PM. by arvintacker. Forum started by anjani sharma
2133
poster for walls
Last answer on 1/2/2021 5:27:27 AM. by S L Gupta (Civil Engg). Forum started by SACHIN
3051
Last answer on 12/17/2020 3:55:26 AM. by Pavan. Forum started by paresh
2195
1369
Mirror in dining roim
Last answer on 8/11/2016 12:31:30 PM. by S L Gupta (Civil Engg). Forum started by Neema
7045
Need Advice regarding Coconut Tree inside the Compound
Last answer on 1/4/2015 12:27:12 PM. by satish. Forum started by Abhi
2538
2620
Last answer on 12/6/2011 11:04:00 AM. by Amit Hasija. Forum started by raghuam
2335
can you use brilliant white gloss paint on mouldings(pop)
Last answer on 1/20/2011 8:22:05 PM. by Dinesh Manaktala. Forum started by coby
Right size cupola
What is binding wire
