Home -> Forums -> Construction -> Vastu Shastra -> Vastu for Construction of House
Thu Jun 18, 2009Total posts : 44
srihari pagadala
srihari pagadala
Topic: Vastu for Construction of House
my plot is east and northy facing, which one is good
The comment above talks about the article   "Vastu for Construction of House"
Go to page: 1 2 3 Next   >>
Fri Jun 19, 2009Post  #1
subrahmanyamkvs
subrahmanyamkvs
Post subject: Vastu for Construction of House
please advise a appropriate plan in a south faced plot with south and east entries as per vaastu
Wed Jul 15, 2009Post  #2
subrahmanyamkvs
subrahmanyamkvs
it is helpful to all individuals if model house plans given for different faced houses.
Wed Sep 09, 2009Post  #3
Reena
Reena
Post subject: How to use the Vastu Purusha Mandala grid??
hi, we are planning to buy a house and have seen a house that we like.. just wanted to check if the house is ok as per Vaastu.. while dividing the house into 9 squares as per the Vaasru Purusha mandala grid, to check the location of each room in the house, should we consider the entire house (including the backyard and front yard) or only the house? and seperately do it for the backyard? please advise..
Mon Nov 23, 2009Post  #4
danish jathanna
danish jathanna
I want to find a way out: I have a narrow plot of land by the sea. In order to fullfill the requiremnt that the house should be on the south east corner of the plot, my house would either face west (the sea) but cut off the view from the rest of the plot, as it would all be behind my house or my house could face north - not the sea (which would defeat the purpose of buying a sea facing plot). Second question: My well (water source) is in the north east corner as required by vastu, but do I need to place the swimming pool also in this corner and the house in the diagonally opposite corner? Pl help... there must be some science to vastu, that accepts the elements and does not ask you to block them.
Sat Dec 05, 2009Post  #5
Shivakumar
Shivakumar
30x40 north face plan
Wed Dec 23, 2009Post  #6
kumareshan
kumareshan
my plot is facing northwest,pls advice a appropriate plan
Fri Feb 05, 2010Post  #7
Sudhakar
Sudhakar
I am constructing house and as per plan staircase is coming to center of building towards east side. The bhramthan is coming in this area. Please advice corrective remedy Sudhakar
Fri Apr 30, 2010Post  #8
dcp
dcp
How to use the compose for direction known
Fri Apr 30, 2010Post  #9
M Jindal
M Jindal
Post subject: Vastu face for plot
The East and North facing plots are appropriate for house construction. Care should be taken while designing the house facing West and South direction because some directions have positive impacts while the other have negative on occupants of the house. For example if the kitchen is in South-East, there are always good results on health. But if the kitchen is in North-East, the health is affected adversely.
Fri Apr 30, 2010Post  #10
M Jindal
M Jindal
Post subject: Vastu Compass
Vastu Compass is a self pointing device that could help you in checking the directions and would recommend you the directions accordingly.
Before buying vastu compass you must understand the charts which comes for every type of room or building type. They are very simple to understand.
Fri Apr 30, 2010Post  #11
M Jindal
M Jindal
Post subject: How to use Vastu Compass
Very simple steps to use vastu compass are:
  • Every chart has its own purpose and significance. You must select the chart as per our purpose/ objective.
  • You just place the chart on the vastu compass in such a way that centre pin of compass should comes out from the middle point of chart. You have to sit in the closed room so that there should be no disturbance from wind or air.
  • Place the given direction-indicating needle on the centre- pin.
  • Just look at the needle, it starts rotating freely. By the time needle would move slowly and would set in one direction. As soon as the needle stops then that is the best direction.
  • Every compass have a red mark on  the needle, that red mark represents north direction. From the north direction, the other directions can be determined easily.
  • You have to rotate the needle in such a way that the “Red” mark on the needle or the ‘N’ pole come exactly over the ‘N’ pole of the chart. Place the instrument on the flat surface. then only it would give you exact results.
Fri May 14, 2010Post  #12
balaji
balaji
I have a south facing plot with the length being 66ft from south to north and 35 feet from eat to west. Where should the kitchen be placed?
Tue Jun 22, 2010Post  #13
jayanthi
jayanthi
I want to construct a house on south facing plot. Please suggest appropriate Plan. Requirement:- Independent portions on ground floor and Ist Floor with common stairs and parking area. Minimum three bedrooms,One Drawing Room, One Kitchen on each floor.
Wed Jun 23, 2010Post  #14
dbasan
dbasan
Vaastu Gurus, I have a north facing plot where construction completed and engineer failed to point the below defect before constrction. North east corner of the plot is not 90degree. It decreases to one and a half feet towards north. East-west on south end is 30 feet and east-west on north end is 31 and half feet. How to correct this defect?
Sun Jul 18, 2010Post  #15
SSrana
SSrana
I want to construct a house on south facing plot with lenght 98X42 size plot. Please suggest appropriate layout Plan. Requirement:- Independent portions on ground floor and Ist Floor with common stairs and parking area. Minimum three bedrooms,One Drawing Room, One Kitchen, Dining hall on each floor.
Thu Jul 22, 2010Post  #16
Bhimraj Solanki
Bhimraj Solanki
Could you please suggest me d drawing for my house having total length of plot is 105 ft lenght x 13 ft width (Road on east side). One room located at west side (Size 16*9 is already constructed, Please give me your mail id so i will send you my drawing
Sat Aug 21, 2010Post  #17
kamlesh bhavnani
kamlesh bhavnani
Road on the west and 8' common passage on the south. The east is 40'.6", the north is 75', the south is 75' +7' = 82' and the west is about 32'. None of the lines is parallel.This 7' is on the west side on the road. Please Help. Can this plot be bought. We can not make up our mind as to whether to buy this plot or not. Thank you
Fri Aug 27, 2010Post  #18
ratnanabh ramesh shetye
my plot size is 14 X 45 facing to westi want to built a house 1bhk.
Tue Aug 31, 2010Post  #19
harikrishna
harikrishna
Hi!! I have bought a 30X40 feet South facing site, planning to build a house on it. I need a plan for basement parking, Ground Floor with a Two bed room House for RENT , First and Second floor would be a duplex house with 4 bedrooms for my own purpose. I would like to have a small garden in the ground floor and also i need to have a garden at the terrace. Can anybody suggest me. Or ant architech can contact me on my emailID "harikrishna.910@gmail.com". Thanks
Thu Sep 16, 2010Post  #20
kiran kumar choure
kiran kumar choure
vastu for toilets ars rsqired
Vastu Shastra-Construction Questions (38)
6892
42-50 west south corner plot please give me vastu house plan 1500 to 1600 sft co
Last answer on 7/3/2020 11:38:42 PM. by seema tyagi. Forum started by muralipuram
1429
i want to a sketch map for construction of my house as per vastu.pl intimate the
Last answer on 5/8/2017 12:39:50 PM. by S L Gupta (Civil Engg). Forum started by RC Tyagi
1181
1216
i have a plot of east road directly hitting my site. please suggest me the vastu
Last answer on 7/4/2020 1:57:40 AM. by S L Gupta (Civil Engg). Forum started by venugopal
2558
Kindly tell vastu tips for west facing plot for construction of dental clinic
Last answer on 10/1/2021 5:05:33 AM. by JesseMWoodley. Forum started by Adarsh
4905
Last answer on 12/31/2020 2:16:17 AM. by Vinika. Forum started by VMUTHAIYAN
plan according to vastu for for my house construction
Last answer on 12/30/2014 11:54:37 AM. by krishna. Forum started by krishna
3852
can anyone suggest floor plan for duplex construction in east facing plot it sho
Last answer on 6/5/2014 2:00:54 PM. by seema tyagi. Forum started by ashok
1836
Please guide for construction of East face. 30*33. Plot size in vastu directon
Last answer on 1/20/2022 11:55:39 PM. by seema tyagi. Forum started by K P MAHABOOB BASHA
3830
2059
i want a good vastu plan for my new construction.south facing.30x40.
Last answer on 10/21/2010 8:47:24 PM. by sabina vanjani. Forum started by ganapathy
2561
dear expert please give me lay out plan of north facing construction for 30*25ft
Last answer on 4/17/2012 5:50:14 PM. by manish. Forum started by manish
1434
i want to change some correction in our map. 40x30 sqft construction east facein
Last answer on 8/9/2017 12:10:04 AM. by S L Gupta (Civil Engg). Forum started by atul pandey
3300
Last answer on 8/11/2017 2:13:58 AM. by HOME. Forum started by Mitesh
1708
I plan my construction for 30*83 feet size north phasing plot, give me some vast
Last answer on 6/21/2016 12:58:07 AM. by Beenu Phogat. Forum started by PARAMJIT KUMAR CHUMBER
1653
i have planing to construction on my 26*60 west facing plot.can any help to sen
Last answer on 7/31/2020 12:25:25 PM. by Beenu Phogat. Forum started by ram sunder
2019
2300
3574
2288
I have not received any sggestion regarding my earlier question about our flat n
Last answer on 10/12/2021 6:24:29 AM. by Priti Arora. Forum started by subrahmanyamkvs
2718
i in kuwait and iam stying in one room where to keep cash box?
Last answer on 9/7/2021 3:50:41 AM. by Kaliopsy. Forum started by rafimeer
2398
pl send me40feetlenth 30feet berth plot, 850feet(or)900feet 2bhk north(or)east f
Last answer on 8/24/2021 3:22:22 AM. by S L Gupta (Civil Engg). Forum started by nagarajan.n
3368
2936
I need layout for making duplex for east facing plot 30 x 50 bedrooms with attac
Last answer on 2/26/2021 4:04:46 AM. by S L Gupta (Civil Engg). Forum started by devinder
3071
can a vastu expert go for bet for best results by vastu remedies ?
Last answer on 2/25/2021 4:27:09 AM. by S.Krishnan. Forum started by harbans singh sekhon
2402
hi ............... i want bed room cupbords designs,plese sand me.
Last answer on 2/8/2021 11:49:19 PM. Forum started by vijay
2462
My plot size is 35by70 .give me map layout diagram. Ground floor for 2 portion o
Last answer on 2/8/2021 11:45:07 PM. by S L Gupta (Civil Engg). Forum started by hemant yogi
2496
Your name :Srinivasan Email adds:vasan09@gmail.com
Last answer on 1/18/2021 9:48:48 PM. by seema tyagi. Forum started by Srinivasan
3991
Last answer on 12/31/2020 2:45:49 AM. by VastuMoorthy. Forum started by senorita
2986
My Plot size is two sides open with two roads at southeast & northeast side of p
Last answer on 12/31/2020 2:31:46 AM. by harbans singh sekhon. Forum started by kstomar2001
3844
Last answer on 12/31/2020 2:29:53 AM. by POSAM BHASKARRAO. Forum started by Sanjeev Saran
2812
Last answer on 12/31/2020 2:14:53 AM. by krishna. Forum started by trisha
2870
Last answer on 12/31/2020 1:54:01 AM. by prasad. Forum started by kalpana sharma
6198
Vastu and Brahmasthan
2023
What will may be full construction estimate cost plot size of 25*45, pl send me
Last answer on 7/4/2020 3:43:22 AM. by S L Gupta (Civil Engg). Forum started by mahendra kumar dutta
1900
Kitchen is in south east and dinning in west. It won't work.
Last answer on 7/3/2020 11:38:06 PM. by S L Gupta (Civil Engg). Forum started by ashok
2133
my date of birth 01-06-1958 vich is my good direction pls
Last answer on 7/3/2020 10:55:27 PM. by S L Gupta (Civil Engg). Forum started by anjaneya
vaastu
HOW
Why
