Home -> Forums -> Construction -> Vastu Shastra -> Vastu Tips for Doors and Windows
Mon Jun 29, 2009Total posts : 33
chinu
chinu
Topic: Vastu Tips for Doors and Windows
hello I am neha , our main door opens at suth west corner & i cant change my house, I have lot os problems,like neighbours relationship this face my kid
The comment above talks about the article   "Vastu Tips for Doors and Windows"
Go to page: 1 2 Next   >>
Wed Jul 15, 2009Post  #1
ankeeta
ankeeta
Post subject: Vastu Tips for Doors and Windows
In my hose main door is opening in South East nad side door in west. Kindly suggest how will it affect my life and also how can I rectify or reduce its bad effectit. no reconstruction possible
Wed Jul 15, 2009Post  #2
ankeeta
ankeeta
There is a Shiv temple right opposite main entrance of my house. In ur article its suggested ther shouldnt be any temple. how will thi saffect me or my family life. Kindly suggest a remedy
Wed Jul 15, 2009Post  #3
Priti Arora
Priti Arora
Post subject: Vastu for main entrance
HelloNeha
It needs complete analysis of house i.e location of rooms, kitchen, toilet, house entrance etc. Please send us architectural plan of your flat. Our vastu expert’s analyse it and give you the solution for vastu defects. Cost for analysis of flat is 1500 to 2500, if you want analysis of your flat. Please create a question in Q&A answers section. Click on the link below to create a question.
Wed Oct 14, 2009Post  #4
sangeeta phadke
sangeeta phadke
my flats fron door is in 70%south and 30% east facing what is yr advise
Wed Oct 21, 2009Post  #5
shivakumar
shivakumar
I am constructing South facing plot,the measurement of main building are East to west i.e South 45feet&West to Northi.e North is 35 feet.I am planning to keep Main Door in south, between 15-20 feet,is it O.K? advise if any.
Wed Oct 21, 2009Post  #6
Deepti
Deepti
Post subject: South facing house entrance
Hi Shiv Kumar
South facing house can have main door in south and southeast. South facing house build according to vastu norms is beneficial for residence.
Deepti
Thu Dec 31, 2009Post  #7
girish
girish
I want to know about vastu remedies for a south west facing main entrance.
Thu Dec 31, 2009Post  #8
girish
girish
On entrance if I hang god's photograph it cause us a problem.
Thu Jan 14, 2010Post  #9
kalpana
kalpana
Can I send a layout to someone to check if everything is ok ? My entrance is from south but the ceiling not very high in the starting as it is just wide gap then on the right connects to the living room. Is it ok ?
Tue Jan 26, 2010Post  #10
Deepak
Deepak
my flat is in the 3rd floor of an apartment. My house entrance is in the north Direction. is it ok?
Sun Feb 14, 2010Post  #11
keshav goenka
keshav goenka
i am going to constructed new home is north facing area 50*100 total , in which disa is best for my main door facing
Tue Mar 30, 2010Post  #12
Clement Gerard
Clement Gerard
Post subject: Expert Advise Needed for south facing house
Hi
I need some advise & suggestions for the attached PPT. The site measures  25 X 17.5 Feet, which is south Facing & Since i do not have the luxury of space i have a layout according to need & my limited learnings & research
I have the Main Door which south facing & There is a Door placed at the north , I guess i have done the right thing here
My first quetion is
1. There is a external staircase at the SW ,which is Just in front of the Main Door ,Is there any harm or have i missed out on anything here & i also have an internal staircare on the Wester wall for the duplex unit. are they in the correct positions?
 2 The second issue is that i have placed Bathrooms with attached toilets on the easter side , have i done the right placements or is there a better way?
Do let me know if any further changes are need & if there will be any negative impact
Thank you in advance
CG
Sat May 22, 2010Post  #13
ashok choudhary
ashok choudhary
which direction Main gate is preferable either N-E cor. or South- East cor
Wed Jun 02, 2010Post  #14
d prasad
d prasad
i have house facing south, entrance on end of south east half i.e more or less centre and another door on north exaclty opposite. is it ok??
Sun Jul 04, 2010Post  #15
shirish s. pawar
shirish s. pawar
mAIN DOOE IS WOODEN AND DECORATED BUT SAFETY DOOR IS MADE UP OF STEEL, WHAT ARE YOUR SUGGESIONS?
Sun Jul 04, 2010Post  #16
shirish s. pawar
shirish s. pawar
MAIN DOOR IS WOODEN AND DECORATED BUT SAFETY DOOR IS MADE UP OF STEEL, WHAT ARE YOUR SUGGESIONS?
Sun Aug 01, 2010Post  #17
akansha
akansha
How can the last point be followed when living in a multi story apratment.
Mon Sep 06, 2010Post  #18
surendra sharma
surendra sharma
please advice me about placement of doors in parallel.How mwny doors canbe placed in a row. If placed more than two doors then what is the solution.
Tue Sep 07, 2010Post  #19
DIBAKAR
DIBAKAR
I have to build an external staircase adjacent to my existing building and under the same roof. Whether the external room, door and windows to be calculated while determining the number of doors, windows and rooms as per vastu
Sat Sep 25, 2010Post  #20
DIBAKAR
DIBAKAR
I have made a outside staircase at south west direction. Whether the dimension of outside staircase is to be calculated for placement of main door.
Vastu Shastra-Construction Questions (39)
3349
Last answer on 1/28/2022 4:52:28 AM. Forum started by RAMJEE MISHRA
3489
2800
Is it neceesary to have many windows and doors in kitchen as I have got only one
Last answer on 7/4/2020 2:44:00 AM. by PR Jawahar. Forum started by veena
3113
please tell me Tulsi plant where site situated in home as vastu tips
Last answer on 12/9/2011 5:33:11 PM. by Amit Hasija. Forum started by Ajay Rana
3961
date of birth 17 july 1968 confirm my vastu tips
Last answer on 11/30/2021 11:37:28 PM. by Johnchen969. Forum started by raghavendra
2640
vastu tips to keep the house lady in good health and long life
Last answer on 12/8/2020 10:50:18 PM. by S L Gupta (Civil Engg). Forum started by rajesh singh chandel
4702
How can we save money and less wasted through vastu tips at home
Last answer on 7/4/2020 2:01:06 AM. by Deepti. Forum started by shalini kulshreshtha
2049
vastu tip for west fecing plot
Last answer on 1/22/2022 11:26:02 AM. by S L Gupta (Civil Engg). Forum started by priyanka sinha
2557
Kindly tell vastu tips for west facing plot for construction of dental clinic
Last answer on 10/1/2021 5:05:33 AM. by JesseMWoodley. Forum started by Adarsh
2425
Last answer on 7/3/2020 9:49:28 PM. by S L Gupta (Civil Engg). Forum started by shridevi
2894
windows n doors
Last answer on 7/4/2020 2:16:10 AM. by JAI PRAKASH. Forum started by Suguresh Patil
2525
6613
what do carpenters charge for doors and windows and wardrobes in lucknow
Last answer on 9/2/2014 10:26:10 PM. by JAI PRAKASH. Forum started by neelam rathi
2738
i need.s windows aluminium with gllas & fire doors pvc construction in india l
Last answer on 2/24/2022 1:02:52 AM. Forum started by muhammad mansoor
5226
5335
I wants windows and door design
Last answer on 7/3/2020 11:34:08 PM. by S L Gupta (Civil Engg). Forum started by Prahlad Kumawat
2482
Why you should buy uPVC Windows by WindowMagic at GharExpert.com
Last answer on 7/12/2011 10:22:48 PM. by Gunjan Utraja. Forum started by mona
1973
I stay in rented house, my main door is at southeast, and facing south please su
Last answer on 11/30/2011 12:00:33 PM. Forum started by Sanjay
14009
Please Suggest vastu tips for west facing Garment Shop
Last answer on 11/6/2021 12:23:52 AM. by S L Gupta (Civil Engg). Forum started by P. Panchal
3572
2288
I have not received any sggestion regarding my earlier question about our flat n
Last answer on 10/12/2021 6:24:29 AM. by Priti Arora. Forum started by subrahmanyamkvs
2717
i in kuwait and iam stying in one room where to keep cash box?
Last answer on 9/7/2021 3:50:41 AM. by Kaliopsy. Forum started by rafimeer
2398
pl send me40feetlenth 30feet berth plot, 850feet(or)900feet 2bhk north(or)east f
Last answer on 8/24/2021 3:22:22 AM. by S L Gupta (Civil Engg). Forum started by nagarajan.n
3368
2935
I need layout for making duplex for east facing plot 30 x 50 bedrooms with attac
Last answer on 2/26/2021 4:04:46 AM. by S L Gupta (Civil Engg). Forum started by devinder
3070
can a vastu expert go for bet for best results by vastu remedies ?
Last answer on 2/25/2021 4:27:09 AM. by S.Krishnan. Forum started by harbans singh sekhon
2402
hi ............... i want bed room cupbords designs,plese sand me.
Last answer on 2/8/2021 11:49:19 PM. Forum started by vijay
My plot size is 35by70 .give me map layout diagram. Ground floor for 2 portion o
Last answer on 2/8/2021 11:45:07 PM. by S L Gupta (Civil Engg). Forum started by hemant yogi
5532
Last answer on 1/26/2021 5:40:38 AM. by VastuMoorthy. Forum started by srihari pagadala
2496
Your name :Srinivasan Email adds:vasan09@gmail.com
Last answer on 1/18/2021 9:48:48 PM. by seema tyagi. Forum started by Srinivasan
3989
Last answer on 12/31/2020 2:45:49 AM. by VastuMoorthy. Forum started by senorita
2984
My Plot size is two sides open with two roads at southeast & northeast side of p
Last answer on 12/31/2020 2:31:46 AM. by harbans singh sekhon. Forum started by kstomar2001
3844
Last answer on 12/31/2020 2:29:53 AM. by POSAM BHASKARRAO. Forum started by Sanjeev Saran
2812
Last answer on 12/31/2020 2:14:53 AM. by krishna. Forum started by trisha
2869
Last answer on 12/31/2020 1:54:01 AM. by prasad. Forum started by kalpana sharma
6197
Vastu and Brahmasthan
2022
What will may be full construction estimate cost plot size of 25*45, pl send me
Last answer on 7/4/2020 3:43:22 AM. by S L Gupta (Civil Engg). Forum started by mahendra kumar dutta
1899
Kitchen is in south east and dinning in west. It won't work.
Last answer on 7/3/2020 11:38:06 PM. by S L Gupta (Civil Engg). Forum started by ashok
2132
my date of birth 01-06-1958 vich is my good direction pls
Last answer on 7/3/2020 10:55:27 PM. by S L Gupta (Civil Engg). Forum started by anjaneya
vaastu
Vastu for Kitchen
Children
Children Room Vastu Tips
Study
Study Room Vastu
Vastu Tips for Plants and Trees
Vastu can be applied on flowers and plants in the house. The plants play significant role in activating positive energy
Vastu Tips for Office
Offices laid out according to Vastu principles are useful in generating financial growth of business. Vastu suggests s..
