Home -> Forums -> Construction -> Layout and House Plans -> Vastu compliant design for 215sqYd plot, dimension - 32 x 59 ft, facing SE
Sun Mar 01, 2015Total posts : 2
Alok
Alok
Topic: Vastu compliant design for 215sqYd plot, dimension - 32 x 59 ft, facing SE
Plot details - 215 sqyd (32 ft x 59 ft), South East facing.
Kindly advise architectural design, HUDA compliant (gurgaon).
Also advise est cost of construction for basement + ground + 2
Sun Mar 01, 2015Post  #1
Hi Alok,
Your Total area is 215*9 = 1935 sq.ft.
As per HUDA you can cover the carpet area of 53.33 % per floor if you are constructing 3 floors (Basement not considered).
The costing for Basement, Ground, First Floor & Second Floor will be around 75 lac's all inclusive of Labour and Material of best range.
Civil Work:                         As per Drawings.
Plumbing Work:                 Including Sanitary
Electrical Work:                 As per Drawings.
Flooring:                           Tiles – Marble. As per choice
Ceiling:                             POP + - designs (False Ceiling – If Required)
Wardrobe:                         Inclusive as per the drawings only.
Walls:                               POP on walls with Emulsion paint finish & Tiles in Bathroom
Window and Door Frames:  Wooden – Saal with Mela-matt polish
Doors                                Flash Doors with veneer laminated and Mela-mat polish
Modular Kitchen                 Tiles and Granite Slab with wooden Modular kitchen.
Mon Mar 02, 2015Post  #2
Post subject: gharexpert services
Please look at the services offered by GharExpert:
A. Architectural Drawing ServicesDrawings Only
In this option, GharExpert will provide you the following services
A.1. Architectural Services:
Architectural service of the house which includes the following:
·         Site plan
·         Floor plans
·         Foundation plan
·         Foundation details
·         Basement drawing
·         Basement details and waterproofing solutions
·         Terrace plan
·         Sections
·         Elevations
·         Toilet details.
·         Internal details such as Staircase ,mumty etc.
·         Door / window Schedule.
·         Details of boundary wall and gate.
·         Specifications for the work to be done.
A.2 Electrical Services:
This service will include the following:
·         Layout showing the position of electric fan, exhaust fan, tube light, bulb, power plug and switches etc.
·         Position of inverter and electrical motor pump etc.
A.3 Plumbing Services:
·         Layout drawing showing the position of washbasin, sink, W.C. seats, shower, bathtub and overhead tank etc.
·         Plumbing drawings which will include the network of laying of the pipes.
·         Water supply and sanitary ware details.
A.4. Structural Services:
·         Structural drawings showing slab reinforcement details.
·         Drawings for foundation of columns, walls and arrangement of steel bars in beams.
For vastu plans, vastu experts work with architect to make a vastu compliant plan
B. Please Look at the packages we offer for Interior Design :
Our design portfolio will include the following drawings.
1.         Layout drawings.
2.         Wall elevations of all rooms.
3.         Ceiling drawings of all rooms.
4.         Flooring drawings of all rooms.
5.         Electrical layout drawings.
6.         Details wherever required.
7.         Wardrobe designs or storage drawings where ever applicable.
8.         Design specifications which will include the color options, texture styles etc.
9.         Toilet detail drawing for all toilets.
10.        Kitchen layout drawings
11.        Suggestions on type of furniture, furnishings and artifacts.
12.        Door and window details.
C. Detailed cost estimate It is a step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved. For example, it will give you the exact quantity of cement bags, bricks, sand, steel and other raw material required and the prices in your area.
D. Vastu Consultancy
Please send us an email if you need more information on support@gharexpert.com   We always look forward to work with you.
3323
can u plz send me a house plan for 32*38 ft west facing plot
Last answer on 7/4/2020 1:59:49 AM. by HOME. Forum started by sujitha
2099
SE CORNER IF LENGTH MORE WHAT WILL BE HAPPEN ACCORDING TO VASTU?
Last answer on 12/16/2020 8:20:56 PM. by Nageshwar. Forum started by sasikumar.arumugam75
3556
Last answer on 3/29/2017 9:32:31 PM. by Saurav anand. Forum started by K M N GANESH
2991
map for plot
Last answer on 1/24/2014 3:43:14 PM. by S L Gupta (Civil Engg). Forum started by jagdish chand
2263
PLAN FOR EAST NORTH ROAD 32 FT WIDE AND 45 FT DEPTH
Last answer on 6/3/2015 9:59:12 AM. by seema tyagi. Forum started by jagdish chand
2213
plan for 32 by 32 east facing plot
Last answer on 12/4/2014 1:05:44 AM. by JAI PRAKASH. Forum started by samir sharma
3592
my plot size 18*32 feet north face 18 feet rastaplease sugest
Last answer on 10/12/2016 2:40:37 PM. by sandeep singh. Forum started by arunmishra
2428
3172
need floor plan for plot 21'(wide)×85'(long) east facing
Last answer on 5/13/2014 1:02:44 PM. by seema tyagi. Forum started by Dhiraj Jain
4556
Last answer on 7/2/2020 10:07:35 PM. by S L Gupta (Civil Engg). Forum started by Pavan Kumar V
3016
East facing vastu compliant house plans
Last answer on 11/15/2014 1:08:19 AM. by JAI PRAKASH. Forum started by PCR.Manohar
1877
Sir I hve a plot 20*50 mujhe vastu k hisab se koi plot map btye
Last answer on 9/14/2020 2:10:29 AM. by Beenu Phogat. Forum started by gaurav
1758
3830
2492
2079
new construction
Last answer on 6/25/2015 10:57:48 AM. by seema tyagi. Forum started by ranise02
2231
Elevation design
Last answer on 8/27/2013 3:33:29 PM. by S L Gupta (Civil Engg). Forum started by asghar
3162
plz send me vastu complaint floor plan for 2 floor plot having dimensions of 30"
Last answer on 2/21/2022 6:22:21 AM. by seema tyagi. Forum started by ashok
1916
I have my parental house facing SE.can u furnish me a plan accoding to vastu
Last answer on 9/17/2020 5:17:55 AM. by S L Gupta (Civil Engg). Forum started by rashmi khera
2690
2924
2188
2184
2790
4520
1890
2284
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
What is acre
Right size cupola
How to Build Stair Steps
Crystal
Crystal Chandelier : Sparkle your Dining
Crystal chandeliers give grace, lavishness and spark to your dining room. With a charming and elegant crystal chandeli..
