Vetrified Flooring Installation Method
Fri Sep 02, 2011Total posts : 1
bhattkalpit
bhattkalpit
Topic: Vetrified Flooring Installation Method
Hi Every One !
What is the proper method of Installation of Vetrified Tiles and what is the standard ratio of raw material (like send, water, cement, etc) for flooring?
Fri Sep 02, 2011Post  #1
Dear Bhattkalpit
The proper method of laying Vetrified Tiles is as under.
Compact the base coat before starting the fixing of tiles, Ensure that the base coat top surface should be even and in level. The mortar used for fixing the tiles is in the ratio of 1:3 i.e cement is 1part and 3 part is coarse sand. The thickness of the mortar should be 20 mm thick. For more detail you should see the flooring section in construction at gharexpert.com web site for ready referance see the link below
http://www.gharexpert.com/articles/Tile-Flooring-1524/Tile-Flooring,-designs--installation-guidelines_0.aspx
flooring
Last answer on 12/16/2015 3:40:28 PM. by JAI PRAKASH. Forum started by arun
2027
3325
2367
how is installation of glass curtain done, details
Last answer on 6/10/2016 12:48:02 PM. Forum started by neetaa gupta
1972
Elctrical wiring
2163
Last answer on 7/4/2020 2:33:32 AM. by S L Gupta (Civil Engg). Forum started by Monish Salhotra
2324
Please let me know difference between vetrified tiles and porsoline tiles.
Last answer on 7/2/2010 3:30:35 PM. by jyoti. Forum started by Sudhakar
1850
can i use vetrified floor tiles (600 x 600 )for my hospital wall( dado )instead
Last answer on 1/29/2011 1:47:18 PM. Forum started by vikram khot
2196
method of road structure, step wise detail caculation of material
Last answer on 3/15/2011 6:14:15 PM. by kanwer sajjad. Forum started by kanwer sajjad
932
any new methods for quick construction ??
Last answer on 7/3/2020 10:05:55 PM. Forum started by PAVAN K
2536
1472
Three Methods Of Wood Floor Maintenance
Last answer on 1/18/2022 11:11:29 AM. by S L Gupta (Civil Engg). Forum started by happywork
2315
Hardwood Flooring and its Installation
Last answer on 11/18/2009 2:06:31 PM. by deodipnsingh. Forum started by suren
3056
Last answer on 7/12/2020 10:44:29 PM. by Girish. Forum started by joseph
1616
FENGSHUI METHOD ....I HAVE NO IDEA..ISIT THAT IT IS ALSO LIKE OUR VASTHU BASED O
Last answer on 4/8/2011 7:23:18 AM. by sabina vanjani. Forum started by D.Ramachandran
1304
Dear Sir , Can You tell about this stone,I mean which type,installation meth
Last answer on 6/6/2013 1:15:16 PM. Forum started by ANAND
1427
Epoxy painting for floors
Last answer on 4/4/2015 12:02:08 PM. by S L Gupta (Civil Engg). Forum started by Akshay Wadke
2062
Last answer on 7/12/2011 3:59:44 PM. by mohit kumar. Forum started by srinivas
2118
Hardwood
Hardwood flooring is one of the expensive yet elegent flooring option. Its installation is not that typical but still ..
Cupola installation tips
Tips for cupola installation
Vinyl
Vinyl Flooring
Tile
Installing Hardwood at an Angle
Ever wondered how to start a diagonal hardwood floor installation? This article provides useful tips for giving your flo
Central
Central Air Conditioner
Central air conditioners are good option for big houses or large building. And proper functioning of central air condi..
How to Install a Sink
Installation of kitchen sink requires just few tools,material and a beautiful sink according to your needs. Read the s..
