Home -> Forums -> Construction -> Tile Flooring -> Vitrified Flooring FloorBase on RCC Slabs
Mon May 13, 2013Total posts : 6
Rajesh
Rajesh
Topic: Vitrified Flooring FloorBase on RCC Slabs
Dear Mr. Gupta- I am very impressed by your responses to various questions people ask you and they are very helpful.
I am Rajesh and constructing the 2nd Floor of my home and need some advise.
I'll give you the details I have so you can give me a simple and best advise...
The 1st Floor roof is 5" thick. Currently the 1st floor roof is open to sky and there is a 2" layer of rakhi+earth in 3:1 ratio and then brick tiles over it and finished with a thin (5mm) cement grouting.
I want to use vitrified tiles (500mmx600mm) for my flooring
My Questions:
#1. What is the best and economical method/process of flooring of my house?
#2. Should I remove the existing rakhi+earth layer so the bare RCC slab is exposed?
#3. What should be the material of the first layer to be laid over the bare RCC slab? Should it be broken bricks? I've heard thekedaars using a word like "Kacha Farsh.." - What is "Kacha Farsh" and is it mandatory for a floor?
#4. Can a vitrified floor be installed directly over the rakhi+earth layer?
Pls advise asap so I can plan my construction and budget well ahead in time.
Thanx in anticipation...
Rajesh
Mon May 13, 2013Post  #1
Dear Rajesh
         First you construct the 2nd floor i.e. lay the slab than finish the slab and wall with plaster.
1.   For laying floor on RCC slab, base coat of screed i.e. 40mm to 50 mm thick cement concrete 1;8;16 with brick ballast  should be laid on the cleaned RCC slab than a layer of 20mm to 25 mm thick cement concrete 1;2;4 is laid on the base coat.This layer is called Katcha farsh or  floor..
2. Remove the rakhi earth and use it on the 2nd floor roof. After removing the earth etc than clean the rcc   surface with broom and water.
3 As on item no 1.
4. No , no any type of floor s not  possible on rakhi and earth except brick flooring.
If you spent some time and see the construction section of gharexpert.com than you will be find lot of material of all kind of construction. See the link below.
http://www.gharexpert.com/articles/Tile-Flooring-1524/Tile-Flooring,-designs--installation-guidelines_0.aspx
Mon May 13, 2013Post  #2
Rajesh
Rajesh
Dear Mr. Gupta-
Many thanx for your prompt and precise answer. Though I was looking for if there's an alternative method of laying the vitrified tile floor on the rakhi foundation so I can somehow save the trouble of removing all that rakhi+earth.
Thank you very much.
Rajesh
Tue May 14, 2013Post  #3
Dear Rajesh
          If you do not want to remove the rakhi and earth than lay the cement concrete 75mm thick 1;8;16 with brick ballast on the compacted bed of rakhi and earth. After that repeat the process as earlier sent to you.
 For doing this your chowkat or door level is  to be raised up to new floor level.
Tue May 14, 2013Post  #4
Rajesh
Rajesh
Respected Mr. Gupta-
Thank you very much for this suggestion and I will go for it now. It will save me all the trouble & cost of removing those rakhi+earth layers which are very compacted as per my test.
I will now remove the brick tiles (which will bring down the floor level by approx 1.5 inch) and use them as my brick ballast and mix it with concrete mixture of 1:8:16 and I dont mind if I've to raise my floor lever by 2 inches - it's worth it comparable to removing all that rakhi.
Thanks much for the advise and sincerely thank you.
Rajesh
Sun May 19, 2013Post  #5
Rajesh
Rajesh
Dear Mr. Gupta-
I've removed all rakhi and earth and I now my bare RCC slab.
I've laid the brick ballast now and got it compressed with DURMUT.
What next pls advise?
Thanx
Rajesh
Mon May 20, 2013Post  #6
Dear Rajesh
      Lay the tiles with cement mortar 1;3 ratio, care should be taken that the brick ballast laid should not dry, it should be wet. If there are more gaps in the brick ballast than lay 20mm cement concrete 1;2;4 ratio on brick ballast to give proper level to tiles. See the article about tiles and laying method.
Tile Flooring-Construction Questions (38)
4045
9836
1914
2388
3720
2281
Last answer on 6/16/2021 11:37:22 AM. by S L Gupta (Civil Engg). Forum started by dnyanesh
3562
1959
Last answer on 10/27/2015 10:43:31 PM. by JAI PRAKASH. Forum started by Baba Dedge
Cost of RCC Terrace slab and Colomns
Last answer on 6/10/2014 2:29:45 PM. Forum started by a.monteiro
2405
I am constructing first floor now. I want to know which flooring is better. Whet
Last answer on 4/17/2011 7:42:19 PM. by S L Gupta (Civil Engg). Forum started by S.BHUPAL RAJU
3457
Kindly guide us for which type of flooring like marble, vitrified tiles is suita
Last answer on 4/12/2010 4:08:33 PM. by M Jindal. Forum started by Sanjay jain
2436
I intend to put non skid tiles at bath (Sunken Slab) at first floor. Please conf
Last answer on 1/23/2013 1:14:36 PM. by S L Gupta (Civil Engg). Forum started by shahidain
2201
floor tiles
2197
Tiles or Marble for Flooring
2601
1441
2948
5847
2996
Flooring in Car Porch
Last answer on 5/31/2021 3:06:20 AM. by Keira Nail. Forum started by P. Panchal
3501
What is the specification for vertified tiles?
Last answer on 12/31/2020 1:19:32 AM. Forum started by Kamal Jindal
2680
Brick tile flooring
Last answer on 7/13/2020 12:31:14 AM. by leelindsey. Forum started by Vinay
2875
Terrace water proofing
2600
ceramic tle
Last answer on 7/13/2020 12:22:37 AM. by leelindsey. Forum started by sabakhan
3042
Last answer on 7/12/2020 10:44:29 PM. by Girish. Forum started by joseph
2704
Balcony flooring
Last answer on 7/11/2020 8:10:08 PM. by S L Gupta (Civil Engg). Forum started by sdk
2340
Need Suggestion
2279
2602
Tiles
Last answer on 7/11/2020 8:08:42 PM. by freekundli. Forum started by Ahmed
2468
Vest tiles
Last answer on 7/11/2020 8:07:00 PM. by S L Gupta (Civil Engg). Forum started by Ahmed
1655
1483
I need to know more about this tile n price and dealer near by my place
Last answer on 3/5/2016 10:24:39 PM. by JAI PRAKASH. Forum started by Rakesh
1473
white bathroom tiles for terrace flooring
Last answer on 10/17/2015 9:47:25 AM. by JAI PRAKASH. Forum started by preeti
1567
How to Apply Tile flooring in a room
Last answer on 3/24/2014 2:15:29 AM. Forum started by Purvi Panchal
2168
down POP designs
2613
tiles
2304
Floor Tile Area difference
Last answer on 7/19/2012 6:28:30 PM. by Ramesh. Forum started by Ramesh
terrace floor tile
Last answer on 9/14/2011 2:03:17 PM. by S L Gupta (Civil Engg). Forum started by nitin dahisaria
What affects the life of doors? What can we do to increase the life of the Aluminium doors?
Tips to increase the life of Aluminium doors....
Which are various types of frames for Aluminium doors?
Frames for Aluminium doors-STEEL FRAME , METAL FRAME , FRAME WITH HIGHLIGHT, METAL DOOR FRAME.......
What are various designs available in side hung doors?
Designs available in Side Hung Doors.....
What is the raw material recommended for painting of metal surface?
Red oxide zinc chromate primer shall be used for iron and steel work including galvanized steel.Zinc chromate primer s..
What precautions do we take in order to make the windows termite free?
The presence sign of termites is through tale tubes. Termites travel in these tubes and are supposed to eat away wood ..
