Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> WC issue
WC issue
Thu Dec 12, 2013Total posts : 1
aammiitt
aammiitt
Topic: WC issue
my house is new....the water level in the WC reduces at times and the bathroom stinks very bad. kindly let me know the cause and remedy.
thanks
Thu Dec 12, 2013Post  #1
Dear Aammiitt
                In my view,  The P-trap used under WC Sheet have either no water seal or proper water seal which is most essential to stop bad smell from the sewer.The water reduces slowly and bad smell starts. Same is the case in bath room where the floor trap used have no water seal. Contact any good experienced plumber for this problem.
1726
WHICH TRAP IS USED FOR INDIAN AND EUROPIAN W.C.
Last answer on 7/30/2014 9:21:40 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
1802
what is the solution/remides if WC in NE
Last answer on 8/7/2011 4:08:53 PM. by sabina vanjani. Forum started by CHANDRASHEKHAR
2379
dampness in bathroom,loft and staircase
Last answer on 8/19/2013 11:25:13 AM. by S L Gupta (Civil Engg). Forum started by Arun
2080
Toilets
1933
My house in underconstration bath sizes 7 feet by 12 feet please manage commat a
Last answer on 1/11/2014 3:55:11 PM. by Harish Chandani. Forum started by muhammad idrees
3044
we are constructing a new floor Bathroom size is 4ft 6" x 7 ft what kind of po
Last answer on 8/21/2011 7:28:11 PM. by mvnisha. Forum started by kiran
2064
What is advantage of this Automate ? Is there any WC with built in INCENERATOR
Last answer on 2/3/2011 6:40:26 PM. Forum started by Mathew John
1826
2016
1993
Can some one advice on the issues involved in designing a double stored roof wit
Last answer on 1/29/2010 6:25:52 PM. by S L Gupta (Civil Engg). Forum started by Anil Kumar Sood
8419
Roof Beam crack
2047
Are there are issues to paint a newly constructed house or is it better to wait
Last answer on 1/30/2013 11:36:55 AM. by S L Gupta (Civil Engg). Forum started by aiyer
2022
SANITARY WARES
Last answer on 11/22/2013 12:17:16 AM. by Purvi Panchal. Forum started by Unnikrishnan
1888
I'm constructing a new house, as per the design the WC in the toilet can fix onl
Last answer on 12/31/2020 2:46:07 AM. by Ajit Tareeka. Forum started by jobi varghese
2388
15470
Solutions / remedies for Bed placed under the Beam.
Last answer on 1/12/2013 11:14:28 PM. by Pavan. Forum started by Sujay S Menon
2850
1473
Hello,can you pls advice on following.1)is it ok to buy BWR grade local flush pi
Last answer on 2/7/2017 1:19:37 PM. by S L Gupta (Civil Engg). Forum started by Manish Chugh
1647
My Land and My home is SouthWest direction. I am living here since last 15 years
Last answer on 11/13/2021 1:11:50 AM. by S L Gupta (Civil Engg). Forum started by S Shah
1885
tap Connection
3628
sunken slab
2508
How to hire a plumber
3498
1675
2321
3860
flush toilet
1960
4721
Cost estimation for sump tank
2219
water supply
2042
Underground Water storage
2231
sewage pipes
2252
commode & flush type
5626
Over-Head water Tank
2337
Vastu for septic tank
2483
2474
Septic Tank Design
3387
3754
position of septic tank
