Home -> Forums -> Construction -> Brick work -> HOW WE CAN PROTECT OUR WALL FROM SALT (SHORA)PECHES
Sun Feb 15, 2015Total posts : 2
gurmeet singh
gurmeet singh
Topic: HOW WE CAN PROTECT OUR WALL FROM SALT (SHORA)PECHES
SALT(SHORA) IN BREICKS
Sun Feb 15, 2015Post  #1
buy good quality of bricks.
Fri Feb 20, 2015Post  #2
Are you using WATER of tube well for construction and curing. Water which have salt in it, gives white patches on walls.
2237
paint
Last answer on 6/30/2021 1:46:52 AM. by S L Gupta (Civil Engg). Forum started by jollyjodhaka
1963
water / salt in walls
Last answer on 3/25/2014 4:46:23 PM. by Abhishek Garg (Builder & Engineer). Forum started by Mrs Francis
2528
2533
Reasons of dampness
1971
1889
kitchen Cabinets
Last answer on 12/17/2015 2:51:28 PM. by JAI PRAKASH. Forum started by ARVIND GOYAL
1543
Dear sir,our bore well water available with 1650 ppm salt content.please suggest
Last answer on 5/9/2016 11:04:57 AM. by S L Gupta (Civil Engg). Forum started by ananth
1526
there is too much salt in the ground on which our house is constructed.due to th
Last answer on 9/2/2014 10:27:25 PM. by JAI PRAKASH. Forum started by Rohini SINGH
1753
1879
1796
Prtotect Cast Iron Cover on underground Tank & Manhole from Theft
Last answer on 10/25/2013 12:34:54 PM. by S L Gupta (Civil Engg). Forum started by Viral
2762
Salt water
2501
Protect your Home from Bugs
Last answer on 12/29/2010 2:52:39 PM. by Nikita. Forum started by trimbak
2174
How to Protect Wood Furniture
Last answer on 9/8/2011 4:16:04 PM. by davidbanks. Forum started by Justin T
2089
Last answer on 4/12/2010 8:36:47 PM. by haritha. Forum started by sujani
2682
Last answer on 1/10/2022 11:40:17 PM. by seema tyagi. Forum started by vaishali
1730
Protect Your Family from Dust
Last answer on 10/29/2014 11:16:30 AM. by T RANJITH KUMAR. Forum started by Husain ansari
1686
How to protect multiwall from UV?
Last answer on 3/17/2016 11:32:49 AM. by S L Gupta (Civil Engg). Forum started by simon lee
2400
hi I would likt to know about the wall drawing is it a paper wall or wall painti
Last answer on 8/27/2021 3:17:36 PM. by . Forum started by mollergh
3673
wals
3267
compound wall
21903
3284
Bedroom Wardrobes information
2248
2211
1500
1971
1734
2228
2528
1506
1913
Brick or ACC block
1659
2154
1708
4716
Brick wall on RCC slab
3935
Protect
Protect
Canvas
Canvas Wall Art
Proper care and protection keeps wood furniture always appealing. If you want to maintain splendor of your wood furnit..
Wall
Wall Decor
Protect
Paint
