Home -> Forums -> Construction -> Foundation -> Wall Thickness
Wall Thickness
Sun Jan 17, 2010Total posts : 1
shankar
shankar
Topic: Wall Thickness
How much of sqft would be consumed as wall thickness for a 9000 sqft? Ground floor + 2 floors.
Thu Jan 21, 2010Post  #1
Post subject: Reply Wall Thickness
Dear Shankar,
The area of walls can be calculated with the help of plan of the proposed house.
S.L.Gupta (Civil Engg.)
Foundation-Construction Questions (38)
8323
3274
2124
Wall Thickness
2585
what is the wall thickness for a 9000 sqft building
Last answer on 4/3/2021 12:46:58 AM. by S L Gupta (Civil Engg). Forum started by shankar
2460
Requirement of wall wall thickness
Last answer on 6/18/2013 8:01:29 PM. by pendli. Forum started by pendli
1789
Hollow Brick Wall thickness for RCC roof
Last answer on 8/10/2015 10:12:46 AM. Forum started by gpeter
1170
7258
4133
2863
2213
3421
Cost of Brick Work
Last answer on 6/4/2014 3:43:02 PM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
2720
2866
Steel calculation
2808
2609
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by S L Gupta (Civil Engg). Forum started by gautam kumar
1732
3238
4143
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1991
Construction Agreement
3091
Foundation
2272
Foundation
1476
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2467
Saria and cement
2678
3179
13267
Steel Type
Canvas
Canvas Wall Art
Wall
Wall Decor
What is the thickness of PVC pipes and diameter for drainage ?
Thickness of PVC Pipes and various diameters for drainage are .........
What is the standard thickness of glass for glass windows?
The standard thickness of glass
Paint
