Home -> Forums -> Construction -> Layout and House Plans -> Wall Thickness
Wall Thickness
Mon Dec 29, 2014Total posts : 1
Sai Pavana
Sai Pavana
Topic: Wall Thickness
What should be the ideal wall thickness for exterior and interior walls of the house.
Mon Dec 29, 2014Post  #1
       The wall thickness should be 9'' for exterior and interior. If there is frame work than interior wall may be 4.5''.
8322
3273
2585
what is the wall thickness for a 9000 sqft building
Last answer on 4/3/2021 12:46:58 AM. by S L Gupta (Civil Engg). Forum started by shankar
2458
Requirement of wall wall thickness
Last answer on 6/18/2013 8:01:29 PM. by pendli. Forum started by pendli
3656
Wall Thickness
1789
Hollow Brick Wall thickness for RCC roof
Last answer on 8/10/2015 10:12:46 AM. Forum started by gpeter
1170
7257
4128
2862
2211
3420
Cost of Brick Work
Last answer on 6/4/2014 3:43:02 PM. by S L Gupta (Civil Engg). Forum started by Subhajit Kundu
2719
2866
Steel calculation
2807
2609
roof thickness
Last answer on 2/26/2022 9:17:15 AM. by S L Gupta (Civil Engg). Forum started by gautam kumar
1732
3233
4143
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2241
3595
2324
2090
2792
1548
2114
Canvas
Canvas Wall Art
Wall
Wall Decor
What is the thickness of PVC pipes and diameter for drainage ?
Thickness of PVC Pipes and various diameters for drainage are .........
What is the standard thickness of glass for glass windows?
The standard thickness of glass
Paint
