Home -> Forums -> Construction -> Plumbing -> Wall mounted cummod vs normal
Sun Jun 29, 2014Total posts : 1
awdhesh
awdhesh
Topic: Wall mounted cummod vs normal
I want to know wall mounted vs normal cummod. Is wall mounted flush having any issue?
In wall mounted flush are there any type. which one is better
and how much costly it would be
Wed Jul 02, 2014Post  #1
Both Have advantages and Dis-advantages:
Wall mount would be costly than the normal and the costing depends upon the brand u choose. But it will give u a luxurious look.
Floor mount is cheap but has leakage issues and take more space and will not allow u to clean the underneath space properly.
2022
SANITARY WARES
Last answer on 11/22/2013 12:17:16 AM. by Purvi Panchal. Forum started by Unnikrishnan
1970
From where can I get this wall mount sink faucet???
Last answer on 9/16/2021 4:08:33 AM. Forum started by Bhavna
2251
commode & flush type
1628
Which arrangement of sanitary items is the best for the bathroom layout attached?
Last answer on 7/3/2020 9:38:05 PM. by S L Gupta (Civil Engg). Forum started by vinu
2955
2966
Hi, this Aquarium mounts on the wall corner and i can mount it in the North East
Last answer on 6/2/2014 11:30:25 AM. by seema tyagi. Forum started by Suresh Aravinsh
2738
Conceling wiresof TV,DVD Player, PS2 etc in Living Room
Last answer on 12/31/2020 1:54:54 AM. by yogi. Forum started by ksrao_74
4764
2052
Tiles Vs Plaster on outer wall
Last answer on 4/14/2014 7:53:27 PM. by awdhesh. Forum started by awdhesh
3012
3841
10933
Lappam vs Wall Putty
13317
Marble Floor Comparison Required (Wonder Vs Katni Vs Dungri)
Last answer on 5/20/2014 12:04:53 AM. by Sunny Bansal. Forum started by Sunny Bansal
1830
TV WALL OR UNIT DESIGN
Last answer on 12/12/2015 6:43:50 PM. by JAI PRAKASH. Forum started by SACHIN
2228
2413
COSTING AND STRENGTH OF WALL
2068
beam and column
1285
I want to build bedroom loft of 2 feet extend from wall. The side walls are 11'
Last answer on 7/4/2020 4:18:19 AM. by Surinder Singh. Forum started by Surinder Singh
2705
type of brick
6270
Water Tank Quality
3114
Hot Water Tank
2914
Sand in Water
3380
Diverters for Bathroom
2561
2145
40516
2083
GI pipe Vs CPVC pipeline
2930
1755
2079
Toilets
5054
2775
2387
1854
3074
Swimming pool
2541
water softner
2681
commode type and flush type
4193
to shut off water to house
A
Canvas
Canvas Wall Art
Wall
Wall Decor
Bathroom Cabinets
Ceiling
Ceiling Fans
