Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Wall on roof slab with no beam underneath
Sun Apr 30, 2017Total posts : 3
Joydeep
Joydeep
Topic: Wall on roof slab with no beam underneath
Sir, in my ground floor roof, there is a area having dimension 8'×9'. there are 10"×10" horizontal beams just under the roof slab around this 8'×9' area. now i want to construct  a 4.5 inch thik separation wall at the middle of this area to make  two bathrooms  with dimensions  4.5'×8' and 4'×8'. now there will be no beam under this separation wall. will it be ok Sir?
Mon May 01, 2017Post  #1
Dear Joydeep,
        Keep the wall height up to 7 feet and give window with glass above 7' height to reduce the load.
2. Lay 4.5'' thick  up word beam with 6'' height with 4 nos 16 mm bars on the slab the end of beam rest on the walls.
Tue May 30, 2017Post  #2
Joydeep
Joydeep
Thank you very much Sir for your reply. I have one more  question. I have a extended roof slab  (cantilever ) which is 1.5 ft extended from wall and length is 9 ft. there are two extended horizontal beams (10"×10"), both are extended 1.5 ft from wall at the two  side of this cantilever. Now if 4.5 inch thick wall is constructed along the9 ft edge of the cantilever , then will it be harmful Sir?
Wed May 31, 2017Post  #3
       There is no harm to construct wall. Try to minimize the load by giving glazing in the wall.
2. you can make 3'' thick wall with hoop iron e.i provide MS Flat in in 3'' wall at 1' height.
4664
Regarding Beam
2054
1875
5691
12251
5861
2557
9195
9893
1656
2525
2177
Room wall not on Beam
Last answer on 7/3/2020 11:24:10 PM. by Purvi Panchal. Forum started by vijay
1769
Roof fabrication advIse
Last answer on 10/21/2015 11:43:50 AM. by S L Gupta (Civil Engg). Forum started by richlyn
4010
labor rate for RCC work
3721
2519
3574
3087
8420
Roof Beam crack
5811
3792
9885
2670
4627
4143
2865
5006
3656
1865
2800
2610
2372
2462
2638
1807
3608
6254
Centering
