Home -> Forums -> Construction -> Start Construction -> Want to construct commercial building in 3200sqft land.
Tue Oct 08, 2013Total posts : 1
sudheer
sudheer
Topic: Want to construct commercial building in 3200sqft land.
       I have 3200sqft land in mysore and i'm planning to construct a 4 storey commercial building, please let me know the procedure and a estimated cost for the building planning for a basement car park. also is 4 or 5 storey allowed for construction?
sudheer
Tue Oct 08, 2013Post  #1
Dear Sudheer
Before starting a new construction project, check whether your area comes in a Earth Quake prone zone. While doing construction work safety measures should be taken for earth quake protection. All components of the building should be tied up with R.C.C. Band at plinth level/DPC level, door lintel level and roof level.Keep in mind the norms/rules of concerned area about building construction.
• Know about the authorities whose sanction is required to start the construction work.
• Know how much time it will take for getting the sanction.
• Search for a qualified architect or designer.
• Prepare house plan according to the area of the plot.
• Arrange structural drawing according to the type of soil.
• Know availability of the building materials, their quality and reputed material suppliers and labor contractor.
• See the availability of good quality of water and availability of electric connection.See link below
http://www.gharexpert.com/articles/Start-Construction-1528/Guidelines-while-Starting-Construction_0.aspx
http://www.gharexpert.com/construction-ideas/start-construction.aspx
For drawing and estimation you may contact support@gharexpert.com
1488
I have plot in Coiambatore, I wish to construct a Commercial building Stilt park
Last answer on 5/22/2017 1:38:27 PM. by S L Gupta (Civil Engg). Forum started by R. Ramasubramanian
1369
Need advice for constructing commercial building with a pent house
Last answer on 9/9/2016 11:42:58 PM. by bhuvaneshwaran bn. Forum started by Mini
2214
cost estimation is on today's Date.
Last answer on 6/1/2015 11:35:08 AM. by S L Gupta (Civil Engg). Forum started by manish
2073
i have comercial plot where i want to construct commercial cum residential with
Last answer on 2/5/2013 11:32:13 AM. by Anupam Anurag. Forum started by KAVITHAS
5988
Marriage Hall Construction
Last answer on 7/21/2021 4:45:40 AM. by Alexander Graf. Forum started by baskar20
4137
Last answer on 6/15/2021 7:30:34 PM. Forum started by baskar20
13025
Last answer on 7/4/2020 1:57:10 AM. by harshit agrawal. Forum started by baskar20
4317
Last answer on 9/9/2021 12:31:10 AM. by S L Gupta (Civil Engg). Forum started by baskar20
4620
Last answer on 10/12/2021 1:06:34 AM. Forum started by baskar20
4260
Last answer on 9/17/2021 1:48:12 PM. by . Forum started by baskar20
12220
Last answer on 2/27/2021 2:53:51 AM. by Ar. Manoj Ralen. Forum started by baskar20
3424
3651
1821
I have a plot 40×40 feet for commercial use with three side raod ,plZz give som
Last answer on 4/4/2018 1:26:38 AM. by S L Gupta (Civil Engg). Forum started by Ankur
3462
3895
Construction software
Last answer on 1/2/2021 5:22:24 AM. by DK. Forum started by tvammu
3800
Orientation of Building
Last answer on 8/6/2010 2:09:05 PM. by narayan. Forum started by pooja
2538
2363
3310
Orientation
Cupola Proportions
Tips for cupola proportions
Fire
How to Design a Garage
