Want to know the Strength of the Roof Slab
Tue Mar 08, 2011Total posts : 1
Sambasiva Rao Ravuri
Topic: Want to know the Strength of the Roof Slab
Hi All,
Recently i come across that there are some measurments for the Roof slab strength like M15, M20 and M25. For these measurements, M15, M20 and M25 what is the Mix ratios of Cement, Sand and Crusher Stones (which can be used for construction).
Please help me to get this information and i really appreciate for the help.
Regards,S Ravuri.
Wed Mar 09, 2011Post  #1
Post subject: Strength of the Roof Slab
Dear Ravuri
             These are grade of cement concrete as M 15, M20, M25.
M15 denotes that the ratio of cement concrete is 1:2:4 means 1 part of cement, 2 parts of course sand and 4 parts of bazri ( stone ballast 12mm to 20 mm)
M20 denotes that the ratio of cement concrete is 1:1.5:3 means 1 part of cement, 1.5 parts of course sand and 3 parts of bazri ( stone ballast 12mm to 20 mm)
M25 denotes that the ratio of cement concrete is 1:1:2 means 1 part of cement, 1 parts of course sand and 2 parts of bazri ( stone ballast 12mm to 20 mm)
3273
Roof Concrete Strength
2092
3754
1908
3980
Roof leakage
2866
2300
6381
kota Stone Roofing
2061
Small Bathroom Ideas or Tips
Last answer on 1/27/2022 7:01:08 AM. by S L Gupta (Civil Engg). Forum started by rammohan.g
3966
cost estimater
2850
2799
hai my house is constructed 7 years ago, now the roof slab is leaking year by y
Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya
191901
5692
1506
Last answer on 10/31/2017 12:00:07 AM. by S L Gupta (Civil Engg). Forum started by div
1067
1764
2136
READY MIX PLASTER
23
27
Cooper
