Home -> Forums -> Construction -> Basement -> Water Leakages in Cellar Building
Fri Sep 25, 2015Total posts : 3
Bharat Kumar
Bharat Kumar
Topic: Water Leakages in Cellar Building
Could anyone please clarify my doubts why does the water leakages will happen in basements in cellar areas and water sumps.
What are the permanent solutions for it. We had done water proofing works also for it don't know why does it fail.
Bharat Kumar
Sun Sep 27, 2015Post  #1
All the side walls and floor has to be made of RCC to avoid this.
Mon Sep 28, 2015Post  #2
Dear Bhart
       In basement construct RCC wall properly vibrated plastered on both side and outer face should be bitumen painted.
Mon Oct 19, 2015Post  #3
vijay
vijay
Post subject: Waterproofing product
Well most of the times it could be due to faulty or inefficient piping and drainage in building while construction, this problem takes time to completely go away. Use Roff Hyseal, it is a waterproof coating.
Process –
1.      Clean the walls completely
2.      2. get rid of all the flaking and everything
3.      3. Apply Hyseal on a clean wet surface
Keep curing it with water for a week this is what helps for lasting effect. I followed this and it has been comparatively better than the other waterproofing products I used. Hope this help you too.
3370
1652
2321
1910
There's a basement space in a building and it locates at backyard of lower level
Last answer on 10/24/2013 11:34:35 AM. by S L Gupta (Civil Engg). Forum started by parth
2076
vastu guide lines for cellar
Last answer on 3/20/2011 1:25:50 PM. Forum started by DURAISWAMY.G
1779
Does under ground cellar influence families living above?
Last answer on 8/18/2011 10:58:33 PM. by D.Ramachandran. Forum started by Nagesh
2024
Cellar is good or bad ?
Last answer on 6/16/2015 4:34:12 AM. by JAI PRAKASH. Forum started by kishore
2767
roof leakage
2833
how to make footing and column for g 2 building on water well
Last answer on 4/1/2013 7:09:40 AM. by Arun. Forum started by Arun
leakage.
Last answer on 7/21/2013 3:08:37 PM. by chethan. Forum started by chethan
2024
5689
2239
Last answer on 1/4/2022 11:02:33 PM. by S L Gupta (Civil Engg). Forum started by nagaraju kakani
3487
Water leakage from the Swimming Pool
Last answer on 8/5/2020 12:58:17 AM. by S L Gupta (Civil Engg). Forum started by S. K. Agarwal
1523
Water leakage from roof concrete
Last answer on 7/3/2020 11:14:37 PM. by S L Gupta (Civil Engg). Forum started by Aravind Rahul
3163
APP membrane
2535
How to arrest leakages through expansion joints.
Last answer on 11/20/2009 10:16:24 AM. by Girish. Forum started by Jagadesh Babu
2298
3121
9061
makan map
2774
17223
1993
2157
design of column
2282
2252
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2797
1970
ffff
1872
4211
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
Preventive
Electric
Orientation
Orientation of Building
Cupola Proportions
Tips for cupola proportions
