Home -> Forums -> Construction -> Water -> Water Storage Solution
Wed Apr 21, 2010Total posts : 6
vinodpawar
vinodpawar
Topic: Water Storage Solution
I am staying in 7 story building.We have grounded water tax which received water supply from BMC and the same is loaded to the terrace water tank. However from last month or so water is not reaching to all houses in the building even though the tank is full. It is found that air is causing this problem but the reason is not known. we have air valve affixed to the line still this problem is experiances. Kindly provide some input on how this problem could be solved. Experts are invited to solve this problem
The comment above talks about the article   "Water Storage Solution"
Fri Apr 23, 2010Post  #1
Post subject: Reply-water storage
Dear Vinod,
The problem you stated here is very serious.  According to me ,you should contact  any experienced plumber. There is one test of pipeline known as “smoke test”. In this test plumber would test the pipeline with the smoke testing machine and will help you further.
S.L.Gupta
Sat Sep 25, 2010Post  #2
mpassi
mpassi
Post subject: Water Storage Solution
Hi, I need to install an overhead tank of 1500lts and want to know if SWISS is a good brand. Also, the last time, there was a leak next to where the pipe was inserted so how does one fix the pipe in an overhead tank? is there a factory fitted solution? HELP!!!
Tue Mar 15, 2011Post  #3
mehta
mehta
I am about to start construction of my house and would like to know if underground storage tank is better in RCC or pvc like sintex etc. The capacity that I want is approx 10000 lits x 2
Tue Mar 15, 2011Post  #4
mehta
mehta
Any civil works contractor/engineer willing to take up construction work of my house of basement and three floors in south Delhi. Should have good experience and a full team to handle it.
Tue Jul 05, 2011Post  #5
kamalesh
kamalesh
Hello, My house is 2 storey house no pillars but build on foundations. I have a 2000 ltrs under ground water tank just outside the building and planning to dig one more inside the house about 7000 ltrs on north eastern corner of the house which is actually a living room. Need some advise, would that affect the foundation of the house? please advise. thanks Kamalesh
Thu Apr 19, 2012Post  #6
Nilesh Rane
Nilesh Rane
I would like to know about the Location of Fish Tank in South direction door home.
3499
2792
Last answer on 7/3/2020 11:53:31 PM. Forum started by mamta
7232
2 lakh litre water tank
6580
roofing on open terrace
1664
Need estimate cost
Last answer on 10/18/2013 4:00:13 PM. by S L Gupta (Civil Engg). Forum started by sanjay
1692
i have constructed a new house. in all bed rooms where all pipes are laid in roo
Last answer on 7/23/2014 12:29:59 PM. by jitendra. Forum started by jitendra
3968
water proofing of water tank
2388
3128
Importance of Water
5630
Over-Head water Tank
2043
Underground Water storage
10066
cost estimation of water storage sump tank
Last answer on 9/26/2010 5:48:55 PM. by sathish. Forum started by manjuks
10028
OVERHEAD WATER STORAGE TANK
Last answer on 3/13/2013 1:37:46 AM. by Purvi Panchal. Forum started by Purvi Panchal
5733
4385
Last answer on 7/4/2020 2:05:07 AM. Forum started by NV MANI
2213
waterproofing concrete flat roof
Last answer on 5/27/2015 1:58:25 PM. by helgajones. Forum started by arindam kar
249
91-9056562757 Love Problem Solution Specialties Baba Ji 91-9056562757 Husband W
Last answer on 12/4/2024 12:29:52 AM. Forum started by Pandit Sahil Sharma Ji
3177
Sump construction
2139
Question Regarding Borewell
1967
Over Head Water Tank
2756
Salt water
3128
Importance of Water
10179
2494
1887
water tank motor capacity
2753
Submersible pump - Bore
2548
Water for Construction
Kitchen Storage Ideas
Storage
Storage Solutions for kids Room
Kids require a lot of storage space to place their toys and playthings. Proper storage ensures safety to the kids as c..
Carpet
Carpet Cleaning Tips
Garage
Garage Organization
Garage has become the storage solution for the house. There is need to have proper garage organization to keep it clut..
Clutter
Clutter Free Bathroom
Make your bathroom clutter free and organized using storage solutions. You can create storage spaces in walls, under ..
Kids
Kids Bedroom Furniture
Make your dream come true by putting unique furniture in kid’s room. Kid’s room needs storage areas because they need ..
Green
Dining Room Cabinets
Cabinets provide decorative and functional storage features. These are available in various colors and are used to st..
