Home -> Forums -> Construction -> Plumbing -> Water Tank Quality
Water Tank Quality
Tue Aug 30, 2011Total posts : 4
Raman Mittal
Raman Mittal
Topic: Water Tank Quality
Hi All,
I am building my two story home. I want to install the water tank at the top. Can you please suggest me, what capacity it will be fine for 2 story building (G+1). I am planning for 1.5KL water tank.
Also, what quality of Plastic Water tank will be good. As in market every one talking about the Water tank Layers. So which is better 2-Layer or 3-Layer water tank and which colour is preferable (Black or White) to prevent the Algae( Green water Jelly) in the water tank.
I am living in Gurgaon and the soil water here is very salty. Please give me your valuable suggestions, so that I will go ahead with the water tank installation.
Wed Aug 31, 2011Post  #1
pankaj
pankaj
Post subject: re: hi
You are looking for water tank quality first of all please note this that water tank material must be marked food grade . 3 layer tank is better  and tank must be white from inside . outer is black or white it does'nt matter . water in white tank become less warmer than in black tanks mostly in summers.
now if water is salty tanks doesnt get effected  the problem will occur with the pipe lines it should be upvc pipes because salty water spoils the  GI pipes within 4 to 5 years.  you can use larger ro waterpurifiers to prevent your GI pipelines.
thanks
pankaj
Wed Aug 31, 2011Post  #2
pankaj
pankaj
Post subject: about the pipes
In my previous  post   by mistake i told you to use UPVC pipes instead of GI pipes .  It should be  PPRC  pipes.
Thu Sep 01, 2011Post  #3
Raman Mittal
Raman Mittal
Post subject: What about the Algae ( the green water jelly)
Hi Pankaj,
THanks for your valuable advice. But I still have some concerns, as you told that we must use the White coloured Water tank. I have heard that the white water tanks develop the Algae very quickly as compared to Black ones.
On the other hand the water in Black  water tanks gets warmer quickly as compared to White ones. So what would you suggest.
Also what is the difference between the 2 or 3 layer water tanks, is it the coating that matters or there are 2-3 sheets of plastics are joined to form a water tank. Recently I have seen the water tank stating a 4-layer one and offering me a price of Rs 4.50/ Litre.
Please give me your views on the same.
Wed Sep 07, 2011Post  #4
George Turner
George Turner
ugh, looks like you will need to do some estimate usage calculations to settle for a certain capacity tank. Perhaps it's wise to choose one on the larger side just to be sure...
5055
2374
water tank
2482
1727
1933
2185
3119
7232
2 lakh litre water tank
1844
1886
water tank motor capacity
2388
2234
1208
sir, building my house now. i read the post about water tanks and the now availa
Last answer on 1/11/2016 11:43:45 AM. by S L Gupta (Civil Engg). Forum started by man
2058
1773
2022
2958
Last answer on 9/1/2015 2:51:50 AM. by JAI PRAKASH. Forum started by sher singh daulta
2219
water supply
2333
3114
Hot Water Tank
2914
Sand in Water
3380
Diverters for Bathroom
2561
2145
40516
2083
GI pipe Vs CPVC pipeline
2931
1755
2080
Toilets
1988
Wall mounted cummod vs normal
5055
2775
2388
1855
3074
Swimming pool
2541
water softner
2682
commode type and flush type
4193
to shut off water to house
Vastu for Water Tank
Preventive
Water for Construction
Reasons of dampness
Fountain fogger/mister to bring the fascinating and mysterious quality to the fountain
The outdoor spaces in the months of June, July and August are very sweaty and sticky even at the evening time. It is lit
60
60 Tips to Save Water
