Home -> Forums -> Construction -> Layout and House Plans -> Water filling after laying the roof (lintel)
Fri Mar 30, 2012Total posts : 1
dev
dev
Topic: Water filling after laying the roof (lintel)
One of my friends is constructing his house. the Lintel/Roof was laid on March 25, 2012. However, due to some problems with the contractor, the contractor deserted. The problem is; the water which was filled until 29 March morning, leaked and none was there to fill water on the newly constructed roof. It was without water for over 30 hours, until my friend who was out of station, reached and arranged a mason and got the water filled. What kind of damage could have been there due to absence of the water from the new roof; and what measures are suggested?
Plz help
Dev.
Sat Mar 31, 2012Post  #1
Dear dev
        I read the contents sent by you. As you stated that RCC ROOF is filled with water for 3-4 days, in this period there is full saturation of cement concrete and filled water again after 30 hours. In my view there is no big harm to  the concrete. You should keep water on the roof at least for15days from the date of laying of concrete.
2835
5695
2361
laying of roof
2240
1757
2237
3807
9211
2161
1842
1800
3091
2338
Related to Sunken Slab
1694
i have constructed a new house. in all bed rooms where all pipes are laid in roo
Last answer on 7/23/2014 12:29:59 PM. by jitendra. Forum started by jitendra
3136
3611
What is the cheapest form of waterporoofing the terrace?
Last answer on 7/21/2012 3:35:37 PM. by S L Gupta (Civil Engg). Forum started by Vipul Hasija
2183
pile work
2902
Terrace water proofing
roofing on open terrace
2695
2927
2191
2188
2802
4524
1894
2289
2272
2774
3467
2361
1975
2248
3600
2329
2095
2796
1552
2120
Earth Filling
Guideline for laying DPC
Cooper
Copyright 2007- 2024 GharExpert.com All rights reserved.
