Water proofing west side facing wall
Sun Apr 21, 2013Total posts : 1
Vineet b
Vineet b
Topic: Water proofing west side facing wall
Didn't know what category to choose, so putting it here.
I've a top floor (4th) flat with west facing windows, during stormy rain the west side wall bleeds from inside along with the windows. I've decided to replace the windows with uPVC as this is a 10yr old construction and the builder had not been fair with the windows at that time. I would appreciate ideas how I can stop the bleeding walls would be highly appreciable. I'm located in Kolkata, so any water proofing experts can get in touch with me too. Just as a note, the walls only bleeds during stormy weather, I.e. when their is a stron west side wind, normal rains are fine.
Thanks.
Mon Apr 22, 2013Post  #1
Administrator
Dear Vineet
             There is gap exist in between window and wall, secondly I think projection of window have not provided with sufficient width.As you want to change the window, than fix the window and care should be taken that no gap or hole is remain, if width of projection is less than cover the window with plastic sheet projection.
Thirdly if the plaster of west side of wall have cracks or uneven, than re plaster the wall with  cement plaster 1;4 ratio.No use of water proofing of wall.
West face House, can we construct North west side face sump
Last answer on 7/4/2020 2:50:11 AM. by S L Gupta (Civil Engg). Forum started by G.Mallikarjuna
2481
i have a plot 31*40" west facing,in HOWRAH .this plot northen side have a water
Last answer on 1/15/2012 7:50:36 PM. Forum started by sovan kumar sett
1703
2400
2233
2768
3163
APP membrane
3968
water proofing of water tank
2444
i have west side kitchen but cooking facing east advice result
Last answer on 11/18/2011 10:27:52 PM. by sathish. Forum started by pradeep
1041
Hi I Need house plan 21feetby 45feet face west side
Last answer on 7/4/2020 3:35:39 AM. by S L Gupta (Civil Engg). Forum started by gurminder
1531
if west side set back is more in the house and north side house wall is not havi
Last answer on 12/12/2017 2:33:18 AM. by S L Gupta (Civil Engg). Forum started by Geetha Kachala
2419
2236
2121
underground water tank
2254
we have house west facing house and south side 15fit road after a temple is ther
Last answer on 2/9/2015 10:15:05 AM. by seema tyagi. Forum started by p.satish kumar
2725
My new plot is west facing,And apartfrom west side gate,which is the best direct
Last answer on 5/31/2012 5:39:05 PM. by Sumsn Kumar Mohanty. Forum started by lakshmana Chari
6580
3051
Last answer on 12/17/2020 3:55:26 AM. by Pavan. Forum started by paresh
1815
My house which is facing frony wall is facing North but while construction by mi
Last answer on 7/23/2011 7:19:07 PM. Forum started by Manjeet singh
15
17
Damp
Damp Proofing
Protect
Preventive
Fire
Basement Design Ideas
