Water tank
Water tank
Wed Oct 01, 2014
karthik
Topic: Water tank
whether water sump of 3000ltrs(brick work) with 1000ltrs overhead tank (total 4000ltrs) capacity is enough for a family of four.
Since contractor tells that if i add additional capacity it might cost close to Rs.9000 per 1000ltrs(brick work).
Kindly suggest me is it sufficient with 3000ltr ground level and 1000ltr overhead.
Wed Oct 01, 2014
Yes its more than enough.
3100
Last answer on 9/19/2014 9:38:22 AM. by
Unoara Design Hub
nishant shah
2358
water tank
Last answer on 1/12/2021 1:31:33 AM. by
vinod jangid
2463
Last answer on 6/3/2021 3:08:10 AM. by
Shreevardhan
1711
Last answer on 11/14/2015 12:33:03 AM. by
kk
1914
Last answer on 11/14/2015 12:31:59 AM. by
kk
2166
Last answer on 1/19/2022 6:10:39 AM. by
HANUMAN
6258
Water Tank Quality
Last answer on 7/22/2021 5:19:42 PM. by
George Turner
Raman Mittal
1828
Last answer on 2/16/2017 2:10:10 PM. by
MRINAL SENGUPTA
2043
sumit
1758
Last answer on 7/4/2016 5:30:43 PM. by
upendra
2941
Last answer on 9/1/2015 2:51:50 AM. by
sher singh daulta
2010
Last answer on 4/25/2015 2:17:43 AM. by
sudha
2319
Last answer on 2/4/2015 11:35:37 AM. by
Arun
2207
water supply
Last answer on 6/18/2014 11:46:36 AM. by
simran
2617
Last answer on 1/20/2021 8:48:02 PM. Forum started by
drlpsingh
5187
Last answer on 9/17/2012 4:28:54 PM. Forum started by
Amatuer
2438
Last answer on 10/3/2012 9:58:30 PM. by
JASBIR MALHOTRA
2105
Last answer on 9/13/2010 4:33:09 PM. Forum started by
Asha Khaitan
1872
water tank motor capacity
Last answer on 3/28/2015 6:29:22 PM. by
Last answer on 4/11/2017 11:10:57 AM. by
2442
Vastu for Water Tank
Reasons of dampness
60 Tips to Save Water
Water for Construction
Sewerage & Plumbing System
Rain Water Harvesting
