Home -> Forums -> Interior -> Home Improvement -> Waterproofing leaks from terrace
Tue Dec 23, 2014Total posts : 6
island
island
Topic: Waterproofing leaks from terrace
Our house was constructed 30 years back and has withstood 2001 earthquake in kutch.
Earthquake has lead to development of micro cracks in terrace floor through which rain water leaks in almost all rooms.
What methods are available for water proofing and which one is the best among them? Approximate costs of each one?
one time cost is not a problem if long term solution is obtained.
Thanks.
Tue Dec 23, 2014Post  #1
Dear Island
             It is better if you take help from local engineer who can give advice after seeing at site personally..However in my opinion redo terracing after dismantling the old.
Wed Dec 24, 2014Post  #2
island
island
Thank you sir.
Actually there are 3 opinions -
1. Redo flooring with an iron (or some other) mesh
2. Applying Dr. Fixit
3. Tiling on terrace - currently there are no tiles. only cement floor.
Which would be better for zero leakage. Also keeping relative costs in mind.
Wed Dec 24, 2014Post  #3
      In my opinion brick tile flooring is the best option.
   Clean the surface of roof and lay polythene sheet on the roof than put good earth on the polythene and made proper slope for drainage of water after it lay brick tiles in mud.After cleaning the surface of tile with broom grout the tile joints with cement mortar 1:3  and do curing and do cement pointing on the joints.
Fri Jan 16, 2015Post  #4
Go with Silicon.
Fri May 15, 2015Post  #5
prit123
prit123
If you're building a concrete foundation, or larger parts of your home involve concrete, you may want to consider waterproofing the concrete itself so that your rooms remain nice and cozy.
Fri May 15, 2015Post  #6
prit123
prit123
Here are a few steps
1. Determine if your concrete house needs waterproofing.
2. Prepare the walls for the coating you have selected.
3. Thoroughly clean the surface of your concrete before      waterproofing.
4. Use a liquid membrane for quickness and economy.
3757
PLEASE TELL ME THE DIFFRENCE BETWEEN B.B.COBA AND IPS TYPE OF WATERPROOFING FOR
Last answer on 7/30/2014 9:22:58 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
2715
please tell me the procedure of bb.coba for terrace waterproofing and please sug
Last answer on 8/24/2020 10:18:48 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
1750
Terrace
Last answer on 8/5/2013 1:06:35 PM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2469
Terrace seepage
Last answer on 9/15/2011 1:33:05 AM. by S L Gupta (Civil Engg). Forum started by P. Panchal
1954
waterproofing on terrace is mandatory?
Last answer on 5/16/2015 7:42:30 PM. by JAI PRAKASH. Forum started by gaurav
3802
1956
How to best waterproof the walls for monsoon?
Last answer on 6/20/2009 12:40:49 AM. by H S Rathi. Forum started by Karan
3499
water proofing
Last answer on 12/2/2020 2:44:35 AM. by leelindsey. Forum started by sunil kumar
13058
what is IPS type waterproofing
Last answer on 9/23/2021 2:31:50 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2894
Terrace water proofing
2798
hai my house is constructed 7 years ago, now the roof slab is leaking year by y
Last answer on 7/3/2020 11:41:25 PM. by S L Gupta (Civil Engg). Forum started by vidya
1436
I need help! How do I seal a leak from my overhead tank?
Last answer on 8/8/2017 11:57:23 AM. by S L Gupta (Civil Engg). Forum started by Arun
1543
Last answer on 1/28/2018 4:51:24 AM. by Er.S.K.Jain. Forum started by S.Nagarajan
1799
2639
where to keep pooja mandir in living room measuring 17X19sq feet with terrace in
Last answer on 3/24/2012 2:53:23 PM. Forum started by srpatil
2296
3121
2259
advise
Last answer on 8/16/2013 1:07:43 PM. by S L Gupta (Civil Engg). Forum started by faroque
5170
2355
Refinish a Vinyl Floor
2521
Introduction
1087
Home appliances
2368
2964
layout plan
2180
Window Curtains For Home
3425
Reg: Interior design software
4764
2717
Living Room Decoration Ideas
2238
2033
2212
floor tiles
796
Online dating
2542
4040
Paint vs Wallpaper
2527
Design for a pooja room
9539
Wall Putty and primer
2012
Straight Drop Awnings
2753
Kids Room Theme
2018
sapty tank
Roof Garden
Tips for Cement Paint
10 things to check before the rain hit your home!
Rain is fun but the fun may not last if your home fails to protect itself and its occupants from the elements. This wr..
Preventive
