We already constructed a 9 inch thick wall of height 7feet and width 11.5 feet
Mon Sep 21, 2020Total posts : 0
Akshaykumar
Akshaykumar
Topic: We already constructed a 9 inch thick wall of height 7feet and width 11.5 feet
We already constructed a 9 inch thick wall of height 7feet and width 11.5 feet over the slab of ground floor without any beam please refer to attachment and kindly suggest is it ok or need to do anything
2332
i am constructed the circular wall of 30 feet dia.,30 feet height
Last answer on 1/6/2022 10:11:07 AM. by S L Gupta (Civil Engg). Forum started by shivprasad
3342
Column footing size
Last answer on 7/4/2020 2:00:01 AM. by S L Gupta (Civil Engg). Forum started by Pooja
3661
Foundation
1543
Cement Slab as roof for elevation
Last answer on 3/8/2017 12:01:54 AM. by S L Gupta (Civil Engg). Forum started by Neel
3380
Square 4 side Pyramid Frame by MS Steel for RCC.
Last answer on 7/29/2014 2:33:14 PM. by S L Gupta (Civil Engg). Forum started by Shailendra Singh
2176
New column footage and pillar very next to the wall of existing building
Last answer on 10/30/2014 5:27:13 PM. by Rachael Suggs. Forum started by Robert
4087
need little calcultaion
Last answer on 7/4/2020 12:03:17 AM. by JAI PRAKASH. Forum started by gaurav
2862
walls
Last answer on 3/9/2021 5:57:05 PM. by S L Gupta (Civil Engg). Forum started by shabbir ali
2207
2076
outside side wall with 4.5 inch width is suggested or not ? will it cause seepag
Last answer on 7/4/2020 2:24:25 AM. by JAI PRAKASH. Forum started by ashok
2232
3076
Swimming pool
2025
I had constructed 4" inch wall on the external wall on the first floor what prec
Last answer on 6/26/2019 10:39:50 PM. by S L Gupta (Civil Engg). Forum started by Badhavath Rajeshwar
1818
I want to change front design of my house
Last answer on 8/15/2020 12:59:30 PM. by tiyas. Forum started by Adnan Saifi
2012
beam sizes
Last answer on 11/29/2014 3:55:42 PM. by S L Gupta (Civil Engg). Forum started by rupesh
2866
Bricks
3993
3178
Sump construction
17
26
32
Designing
Designing a Foundation
Canvas
Canvas Wall Art
