Home -> Forums -> Construction -> Ground work -> Weight on Sump Tank
Weight on Sump Tank
Mon Jan 19, 2015Total posts : 2
awdhesh
awdhesh
Topic: Weight on Sump Tank
My sump tank was constructed first, then the building foundation and so on
. The height of building foundation was increased by 1 ft. Now the Sump will be covered by 1 ft of soil and Jelly stuff on which Car will be parked.
One of my friend is suggesting the there is too much of load on the Sump concrete slab. The slab is 4 to 5 inch thick.
Please suggest if the problem is genuine?
what should I do ?
Wed Jan 21, 2015Post  #1
Dear Awdhesh
            There is no problem for car weight on sump with earth and jelly.
Sat Jan 24, 2015Post  #2
There is no problem.
5055
2195
Last answer on 12/31/2020 8:58:35 PM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
2100
2645
Which is better for losing weight: peanuts or mahana?
Last answer on 9/24/2021 1:34:49 PM. Forum started by Celly Swehykol
664
What do you think about the effectiveness of diets for rapid weight loss?
Last answer on 6/14/2021 9:43:38 AM. by Salammm. Forum started by Salammm
4721
Cost estimation for sump tank
2285
HI WHAT IS THE WEIGHT OF 1MX1M BARBEDWIRE FOR @10GAUGE
Last answer on 12/31/2020 2:08:42 AM. by H S Rathi. Forum started by K.SRINIVASAN
5088
cladding of tiles for sump tank
Last answer on 8/20/2020 1:29:34 AM. Forum started by lakshminarayanaswamy
10066
cost estimation of water storage sump tank
Last answer on 9/26/2010 5:48:55 PM. by sathish. Forum started by manjuks
2756
Construct a sump / basement water tank in drawing / living room
Last answer on 7/5/2011 4:18:52 PM. Forum started by kamalesh
2219
2145
13537
3370
10178
1637
West face House, can we construct North west side face sump
Last answer on 7/4/2020 2:50:11 AM. by S L Gupta (Civil Engg). Forum started by G.Mallikarjuna
3498
2533
what happens when sump comes at north east corner inside the room
Last answer on 7/3/2020 10:54:04 PM. by S L Gupta (Civil Engg). Forum started by vedamurthy
1966
Over Head Water Tank
2995
8159
software
3899
2730
1833
lanterns
3133
false ceiling
2245
about construction
1786
4153
Cement Coba
3076
Water Harvesting System
1676
1758
water tank
2058
1760
1634
Pool construction cost
1993
2738
Regarding roof beam
Fire Stair case
2645
2371
super structure
Vastu for Water Tank
Preventive
Density of Coarse Aggregate
Reasons of dampness
